Local Time 22:20 24 Oct 2026 Privacy Policy
Forum Index : Windmills : U-bolts for Glenn’s smart. hub
domwild
Posted: 05:24pm 12 Jun 2013
The holes for Glenn's hub are rather large and the standard 1" U-bolts I can buy at Bunnings are too small in dia. leading to the exhaust tubes not centering along the required axis.
I suspect I have to go to a fastener place in WA and specifically what should I ask for? Do I need to ask for stainless steel ones for the strength?
Thanks.
Winston Churchill
Madness
Posted: 05:38pm 12 Jun 2013
Stainless steel bolts are not as strong, if you want strength specify high tensile steel. Any bolt shop should be able to help you and would be far cheaper than bunnings, they advertise they are cheaper but that is not true.
Posted: 10:00pm 12 Jun 2013
Yeah what Madness said.
The U-bolts are pretty important in that build, so buy the biggest you can that fit neatly over the 1 inch pipe, even if it means you need to enlarge or offset the through holes in the steel plate. From memory the thickness of the U-bolt was about 10mm in my case.
domwild
Posted: 12:46pm 14 Jun 2013
Thanks for replies.
Winston Churchill
