Local Time 22:34 24 Oct 2026 Privacy Policy
Forum Index : Windmills : low voltage disconnect
flc1
Posted: 11:40pm 11 May 2013
Gday, I was wondering if anybody knows of a 24v lvd that can be adjusted from lvd of about 25.8 to lvr of about 26.2 , rated about 20 to 30 amps? I have searched for a while now online etc and can't find anything that will disconnect at that voltage ,all are lower voltage diconnect,I don't want to pull to much load from batterys,so they last longer, thanks ,,,Fred
Posted: 12:12am 12 May 2013
You dont say if you want to build or purchase a controller to suit.
If its a circuit design you are looking for than have you found this circuit by Gizmo.
http://www.thebackshed.com/Windmill/articles/TL084-Controlle r.asp
Or is it you want an off the shelf item to match your needs.
fillm
Posted: 11:40am 12 May 2013
If its an of the shelf item then this is the best, a Plasmatronics PL20 , use program 4 and you can set voltages till your hearts content .
It will do a 20 A load directly as well as a myriad of other well thought about settings for battery management .
flc1
Posted: 12:23am 14 May 2013
thanks for your help,off the shelf item for me,that pl 20 looks like the one thanks,,,,FredEdited by flc1 2013-05-15
