Forum Index : Windmills : F&P setup
| DuvalAppliance Newbie Joined: 28/10/2012 Location: United StatesPosts: 2 |
OK what is the best setup for across the board power should i go the delta config..? or is there a better setup I have the new style rotor and stator so i can wire it however needed i have some great ideas but i need help... and once its setup and making power how do i store it? the sell it back to the electric co.. and if i have 2 rotors and stators to setup how many watts will i get from each setup? Please send me in the right dir.... thank you Newbe William |
Hi William Will need some more infomation. What voltage do you want to run the system at? If its a grid tie inverter you plan to use, what model? As a rule, you can expect a watt per rpm for a F&P. So at 200 rpm, you can get 200 watts. This rule can be bent quite a lot, but its a good starting point for a beginner. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
ok 12 volt system i have no idea of what i will need but i will spen the money to make it right... i have 4 of the f&P rotor and stators's waiting on me to set them up.... I have room for lots of them to setup and can get more of them so i can sell the power back and that is what i am looking to do. I would like a VERTICAL one but need to find cheep parts |
| govertical Guru Joined: 11/12/2008 Location: United StatesPosts: 383 |
Hi, I am working on a F&P project, how many coils are on the stator? just because your a GURU or forum administer does not mean your always correct :) |
mac46![]() Guru Joined: 07/02/2008 Location: United StatesPosts: 412 |
William, You stated that you need to be advised to the set up... Going with vertical may not be you'r best choice right now. A horizontal mill or mills would be quicker/easier and produce more power for the investment. This may be better for you until you become more versed with the systems and capibilities. 12 volt may not be the optium voltage either, most are changeing over to 48 volt systems...just depends on what you want to use the power for / how you store it / how far away the tower...(towers)...are from the batteries. Most towers need to be above 50 feet, depends on you'r conditions, but clean linear air/wind is much better above 100 feet. Just my thoughts... Mac46 I'm just a farmer |
