Local Time 19:30 24 Oct 2026 Privacy Policy
Forum Index : Windmills : starting my tower
brucedownunder2
Posted: 11:04pm 02 Nov 2005
Hi Group, I've started bolting steel together for a guyed mast that will hold my 10footer,I hope. It will be a permenent stub tower guyed at 25 feet.
At the bottom of this will be a pivot pin that will take the raise and lower mast section--the top of the stub mast acting as a gin-pole with a pulley block and the raising /lowering wire rope coming down to the base,then away to the winch.
Total height will be in the order of 55 feet,depending on the size of the mill.-I'll be able to shange things easily.
Attached is a couple of pic's of the raising of the gin-pole,well,actually a ginpole to raise a ginpole .
If you have never had rigging experience,DON'T attempt this . Get someone in that is a rigger.
Bruce
Bushboy
ozetrade
Posted: 10:00am 04 Nov 2005
Hi Bruce,
Sure glad I'm not trying to do the things you do. You must be very experienced/confident in your abilities. I'd hate to put structure up that high and have to maintain it.
Thinking of heading down your way camping for a weekend - is that offer to visit still open?
Greg
Greg
Just North of Brisbane in Redcliffe
OZeTrade.net
brucedownunder2
Posted: 08:40pm 04 Nov 2005
 Hi Greg, yes come on down, Just call me first (07) 55453513 . around 40 minutes from the gold coast ,out towards Canungra.
The mast is very strong,proving a bit difficult to raise,but when it's up it will be very strong and able to support most anything I 'm likely to give it.
I'm a licenced rigger ,so I've done a bit of this type of thing in past years-and have all the gear for doing it .
Bruce
Bushboy
MrBungle
Posted: 08:38am 11 Nov 2005
Hiya Bruce
Good to see the mast is on its way.
Gave up on the trig did ya? lol, I don't blame you, It probably wouldn't have been accurate enough anyway.
Is that a tree stump as your base or are my eyes playing tricks on me?
Simo
brucedownunder2
Posted: 01:48am 12 Nov 2005
Hi Simo, Yes , a big fella Bloodwood stump that I soaked in creosote. Should see me out !
Haven't given up on the trig stuff --just doing it a different way ,so thanks for your help.
Bruce
Bushboy
MrBungle
Posted: 04:56pm 14 Nov 2005
Brilliant idea!
Sure wish I had land with a beautifull view like that.
I'm stuck in the ugly burb's with ugly ugly neighbours, kinda limits me to a small, short and hopefully quiet VAWT :(
Someday though......
