Forum Index : Windmills : lots of wind,Yahoo!
Robert_VK2BBR![]() Regular Member Joined: 31/12/2006 Location: AustraliaPosts: 67 |
Finally after being becalmed for near 2 weeks, it is blowing a beaut southerly here. My F&P toy is putting 10+ amps into the 6 volt battery bank. As per murphy's law I am about 24 hours behind putting up my second mill for the 24 volt bank. Robert 1555 W grid connect system since Jan 08 both vehicles running on modified, used vege oil. |
Gill![]() Senior Member Joined: 11/11/2006 Location: AustraliaPosts: 669 |
That wind programe writer must be one clever fellow, devious too was working fine... til the smoke got out. Cheers Gill _Cairns, FNQ |
Half your luck Robert, had very little here the last few days. You realise if you put up your 2nd windmill the wind will go away for at least 3 days, its a scientificaly proven fact. Just like if you wash you car it will rain later that day. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
hi guys, yes murphy sucked me in, i didnt finish the 2nd mill, the wind stopped so I thought i had plenty of time, guess what, it started blowing a southerly all over again. The next one to go up is a 3P 80 series wired s/p half & half so to speak, ie 7 coils in series each phase and then the two halves in parallel. Hoping that this will be better for the 24V bank. cheers Robert 1555 W grid connect system since Jan 08 both vehicles running on modified, used vege oil. |
| brucedownunder2 Guru Joined: 14/09/2005 Location: AustraliaPosts: 1548 |
Hello Robert,, I'd be pleased to hear how that configuration performs,please. Thats the new series Stator and Rotor you are talking about ?? The non-cogging type ?? I've had mine up ,but not much wind , when the breeze did come in ,I thought the o/p was fairly dismal --heaps of volts ,but hardly any current-max 3 amps @ 26 odd volts. Let us know if you are using the new series Stators and Rotors,thanks Bruce Bushboy |
Hi Bruce, no I am still using the old one, just dividing it in half, in the hope that the prevailing light NE will put a trickle into the 24v bank Robert 1555 W grid connect system since Jan 08 both vehicles running on modified, used vege oil. |
