Local Time 23:26 24 Oct 2026 Privacy Policy
Forum Index : Windmills : F&P issue
rippleephex
Posted: 04:48pm 19 May 2012
Hi All,
I'm having an issue with my F&P Generator. i have wired it so that it is in the star configuration and have the 3 phase cables running to a rectifier. The issue i'm having is that on the 3 phase side of the rectifier i'm getting 18+ volts easily when spun by hand, however on the DC side of the rectifier i'm barely getting 1 volt. I have tried 2 rectifiers and both have the same issue.
any ideas? this is my first wind generator :)
Posted: 08:22pm 19 May 2012
Are you setting your meter to read DC volts on the rectifier output?
rippleephex
Posted: 08:46pm 19 May 2012
Hi Glenn,
Thanks for you help. That was the issue, i have used this multimeter a lot for car radios and a few other things, i just got the settings mixed up :S thanks again! much appreciated!
Heath
