Local Time 23:26 24 Oct 2026 Privacy Policy
Forum Index : Windmills : pmm
guitarbab
Posted: 05:11pm 06 May 2012
hello i was wondering if someone could tell me if this treadmill moter will work for wind turbine and if i need to use a rectifier to go from dc to ac volts dc100 rpm 3250 amps 23a insul f amb 40c direct current pmm cambridge moter works
Posted: 11:03pm 06 May 2012
Hi guitarbab
It's not really suitable unless you can gear it up some how, and thats not recommended, lots of moving parts and stuffing around for a small windmill.
It's a 100v motor that runs at 3250 rpm. So thats 100v / 3250 rpm gives us 0.03 volts per rpm. A typical small wind turbine runs between 100 and 600 rpm, so this motor would only make between 3 and 18 volts. For a 24 volt system, forget it. For a 12v system, it will start making power at over 400 rpm, which is very very high!
A 1:2 gear step up will brint the rpm down to 200 for the turbine, which is OK-ish.
You could also look at using a boost converter to step up the voltage at low RPM, but this may be a bit complicated.
Diodes are used to convert AC to DC, not the other way around.
What did you hope to achieve with this motor?
guitarbab
Posted: 12:41am 07 May 2012
if i could get a few amps to charge batteries would be good I have a 10si altinater that i bought off ebay that is charging pretty well I found the treadmill moter for cheap so thought i would try it but doesnt sound like it is worth it thanks for your reply
