Forum Index : Windmills : How to insulate damage copper wires
ozetrade![]() Regular Member Joined: 15/10/2005 Location: AustraliaPosts: 59 |
Hi Peoples I've just started my second F&P rewire. I decided I would grind the terminal post's down to make a neat finish. When I did this the grinder made contact with two of the wires - just enough to take the dark copper colour off. What can I do reinsulate these wires? Thanks, Greg Greg Just North of Brisbane in Redcliffe OZeTrade.net |
Hi Greg Go and buy ( steal from the missus ) some nail polish. Its the same sort of stuff and works a treat. If you have nicked the wire deeply, ie took a chunk out of it, use your soldering iron and solder the wire back up to its original thickness before applying the nail polish. Glenn. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Thanks Glen, I thought I'd really stuffed it - neat trick. Greg Greg Just North of Brisbane in Redcliffe OZeTrade.net |
