Forum Index : Windmills : prospective generator
| curiosity Newbie Joined: 04/12/2011 Location: AustraliaPosts: 31 |
I have an aircraft generator very similar to http://us.ebid.net/for-sale/aircraft-d-c-generator-type-p-mf rs-43879429.htm and was wondering if it would make a decent wind generator? |
Hi Curiosity Nah, it would be pretty hopeless. It looks like a series wound generator, and reading the description, it supplies 28 volts at 5,000 to 10,000 RPM. Thats about 20 times to fast for a wind turbine. It would, however, make a mean motor for a kids scoota! Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| yahoo2 Guru Joined: 05/04/2011 Location: AustraliaPosts: 1166 |
spec plate says output 200 amps and rev range 5000 to 10,000 rpm. they make good motor driven chargers for big 24 volt battery banks but need good support bearings and at least a 2 belt pulley. I'm confused, no wait... maybe I'm not... |
I realize a windmill would never spin that fast. I wouldn't be spinning it directly from the blade head. Possibly from a stepped gear or pulley set up to achieve the speed required |
| Tinker Guru Joined: 07/11/2007 Location: AustraliaPosts: 1904 |
A 20:1 gearing ratio is a *very* big ask for that requirement. Personally, I would not bother with bigger than 6: 1 ratios which can just about be done with a single reduction. Klaus |
Thanks guys. I thought maybe a vawt would do it but 6:1 is a far cry from 20:1 |
| Rastus Guru Joined: 29/10/2010 Location: AustraliaPosts: 301 |
Hi Glenn, Using 5 of the Goe222 blades,can you provide a guestimated Rpm capped speed,using a diameter of your choice,please? I havn't checked,but I vaguelly remember seeing a 5 blade mill on an earlier thread someware and I'm hoping you can fill in some details.Cheers Rastus see Rastus graduate advise generously |
