Local Time 23:13 24 Oct 2026 Privacy Policy
Forum Index : Windmills : LG Washing Machine DD motor
Fish
Posted: 05:09pm 28 Jan 2012
Hi - I need some guidance with a problem I have on my hands.
I have built a wind generator from a LG washing machine DD motor and
the cogging is extremely severe when applying light loads.
I have looked at what is on the site but not too sure if I should section
the coils as they are already 12 coils per phase and wired 3 phase with
12 magnets.
I am not sure what battery configuration I am going to be charging, either 12 or 24 v.
My aim is to move my light off then grid by the end of June.
My turbine is fashioned on the Lentz design.
Question should I section the motor from 3 phase to 6 phase to reduce the cogging.
regards
Madness
Posted: 09:27pm 28 Jan 2012
Is the problem getting started or after it has started turning. If it is the initial startup have you tried fileing the long edges on the ends of coils so that they are rounded, each one will look like a speed bump. It helps a lot with the F & P Motors.
Fish
Posted: 11:24am 29 Jan 2012
Greetings - Madness, I have not installed the blades as yet. It is when I turn it by hand that
I feel that the turbine will need a hurricane to get it turning. Without the rectification
diodes in, it does spins freely.
I have not dressed the coil poles as yet; I was looking at more changing the configuration.
Madness, I’m hesitant to change the configuration as it seems that the magnets play a
major part if one can change or not.
Here is SA it is difficult to get hold of the DD motors and I paid an arm and a leg for mine.
So I need to be sure what I do is correct, I’ll look at rounding the pole pieces
Madness
Posted: 12:09pm 29 Jan 2012
You better check your diodes, I think you will find you are creating a short which is acting as an electrical brake.
Have a look at the Standard F&P wiring it is the first on this link.
Wiring Diagram Edited by Madness 2012-01-30
Fish
Posted: 12:38pm 29 Jan 2012
The diodes are fine, tested and turns a small dc fan.
The page where you pointed me too also shows configuration
change to 6 phase
Madness
Posted: 12:43pm 29 Jan 2012
It should be no harder to start with the diodes connected, I am sure something is wrong, could be just one that is backwards. I think you need to focus on the present fault rather than extra phases.
turnymf
Posted: 01:06pm 29 Jan 2012
Gotta agree with madness
Shouldn't make it harder to turn by just adding diodes unless one is crook or in the wrong way
Cogging is when the mags align with the poles of the stator, attracted to the core and thus resist rotation, as you can spin freely this doesn't sound like your trouble
Does it rotate freely with diodes and no load?
BobMann
Posted: 01:08pm 29 Jan 2012
Hello
I have spent a many a year on upgrading the F&P stator to be a good work horse.
There are 2 thing at work here.
1 cogging is the fource to break free the magnet fron the steel poles with open wires.
2 the fource to make power in to a power source kind of like blowing through a straw.
Here is VID to show about this and what I did to over come this.
Mann Smart Controller
Bob Mann
Tree Top Wind Mill
Fish
Posted: 03:47pm 29 Jan 2012
Greeting All
Just maybe one of the diodes are fried, I’ll check them again.
I'm hooked on the controller, is it available on the market?
On open circuit the machine turns freely, but add a tiny load
then we need to look for Popeye for help.
I am sure the controller is what I need to free up the machine.
If I am able to source another DD motor, then I’ll attempt to
reconfigure the coils
Madness
Posted: 09:34pm 29 Jan 2012
Try it connected to a battery, there should be no current flow until it gets up to at least 100 RPM. You don't need any fancy controller to achieve that.
turnymf
Posted: 11:25pm 29 Jan 2012
  BobMann said   Hello
Bob Mann
Tree Top Wind Mill
How many years have you been working on smart drives Bob?
Fish, Steve's controller is still development stage and far from retail
How big is the lenz you are thinking about using?
BobMann
Posted: 11:56pm 29 Jan 2012
It is well docmented how long my work on Smart Drives and I think I would know when Steves
bourd is ready for prime time seeing I have funded some of it.
Please just do the same test spin up one by hand in to a battery and show watts and volts and post a VID I am shore ever one would love to see it.
If some one is looking for low cost Lenz I have 2 sets of 3- 4 fts.
I have moved up to the C floating Rotor Blade.
Bob Mann
turnymf
Posted: 09:30am 30 Jan 2012
  BobMann said   It is well docmented how long my work on Smart Drives and I think I would know when Steves
About a year according to your utube of 24/4/2011, ever heard of spell check Bob?
Fish. how many watts do you think you use for your lighting?
Fish
Posted: 03:42pm 30 Jan 2012
Just feel uncomfortable when an attract occurs, mistakes creep in all the time.
First, I have designed the blade length to be 1200mm on a 500mm radius.
The estimated wattage I use per night is round about 1200 watts.
Have already moved some of my light to 220v LED type lights.
The system I am putting together is: solar/Wind charging a set of batteries then
inverting back to 220v AC. It’s really about building the wind generator than going green, but if I
can show the wife positive spinoffs, then she will fund my other projects.
turnymf
Posted: 11:43pm 31 Jan 2012
I hope your in a windy spot, otherwise a lenz of that size will only give you a small percentage of that wattage
How are your diodes?
I use flattery of my misses, and if that doesn't work a bit of in out does the trick
Fish
Posted: 02:06pm 01 Feb 2012
Turnymf – thanks for staying on-board. Not sure that my turbine is a Lenz, it is just fashioned along those lines. I have had one up, just the blades, no load, and it was spinning at about 6Km/h, that’s about average for our windy months. Now that I have a motor I can go ahead and put the unit together. This is why I here now to find out about the cogging effect.
I have changed the diodes and it has made a difference, I am now going to complete the wind turbine, and let see what results I get. The cogging has made me want to increase the size of my blade to 1200 high by 600 radiuses and the blade size 280mm by 50mm.
Main principal of the VAWT in my case is to charge batteries.
As for the wife comment, that was to light the mood.
Edited by Fish 2012-02-03
Fish
Posted: 06:41pm 09 Feb 2012
Reading through the post. I need to post another question to whoever has the experience
in building a VAWT with the washing machine motor. I want to use my VAWT to charge 24V batteries.
Question: Will a VWAT of the size I am building, read previous post, do the job.?
I have to use VWAT, as I am in a built up area.
turnymf
Posted: 01:01am 10 Feb 2012
Hi Fish
That really depends on a few things
How much load are you applying to the batteries?
How windy is your location?
How efficient is the mill at extracting energy from the wind ?
Fish
Posted: 03:29pm 10 Feb 2012
Thanks Turnymf - I'll carry on with the project and see what results I get from the mill. My inverter arrived yesterday, now waiting for the battries.
keep you postedEdited by Fish 2012-02-13
Fish
Posted: 09:07am 08 Aug 2012
Hi Guys
After some delay my project is again on track. I now need to
rewire my stator to produce 24v with 6-8km wind.
The stator is a 36 coil hub,I was just about to rewire to
3x4coil system when I checked and found the write-up on the 7 phase
system. What I like was the no cogging in this configuration.
My question is, with a 36 coils system can I go 6x6coil and get the same effect,
no cogging and enough watts to charge a 24v battery system ?
Here in South Africa the DD motors are like hens teeth and very pricey.
thus the concern of making a error in the configuration.
thanks.
