Local Time 02:03 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Trev’s new cast hub fitting
brucedownunder2
Posted: 08:33pm 27 Jan 2007
Hi guys, I have a "Trev" new cast Al hub with the spline milled internal-Great piece of work.
? is , has anyone carved blades for this sort of hub?
Trev, have you thought about a set of 14 foot ,or so, f/g blades for these hubs ,along the lines of the "white-Pointer" set you made some time back.
I'm a bit confused as to where to ,or how to , mark out the timber for carving a set--any help would be appreciated. Hope to go wide and ,say,around 14 foot ,
Bruce
Bushboy
Trev
Posted: 11:13pm 29 Jan 2007
No problem to do it Bruce,
the 14 foot is diameter I assume, so blade length is 7 foot or so.???
Trev @ drivebynature.com
