Forum Index : Windmills : magnet workable temp table
| Hugh Regular Member Joined: 26/11/2006 Location: CanadaPosts: 41 |
thnxs allways |
Hey Hugh, thats a very good table. Can I put it on the web site as a reference thingy doodad? Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
yeh its a good thingy doodad hugh thnxs allways |
Thanks mate. I'll stick on the web site this weekend. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
hey Gizmo Have you ever heard of someone building a really sturdy tower, using massive blades (not necessarily long ones but designed along the style of the old mill grinding blades ) & transferring that power down a shaft. it would be a lot slower revs but from there you could step up the revs considerably. My son and I have had quite a few arguments about this. What do you think Hugh thnxs allways |
| thefinis Regular Member Joined: 23/08/2006 Location: United StatesPosts: 53 |
I dislike posting links to other sites but here is a link to a thread that is almost like what you are asking about. It is of course from a mate down under. http://www.fieldlines.com/story/2006/1/9/103933/9137 I will say this the more bearings, gearboxs, power transfers that you run the power through the more of it you lose. Making the diameter bigger will offset many of the losses but slows rpms and means using a bigger stronger tower. Finis Texas born and bred |
Thanks Fini just perfect Gizmo this has got to be the most original idea I've seen in all the perusing of alt. power sites. It would be a great general posting for this site ( I think ) Hugh thnxs allways |
