Local Time 02:03 25 Oct 2026 Privacy Policy
Forum Index : Windmills : making generators
Mykd
Posted: 09:00pm 25 Jan 2007
Hi All, I have a shaded pole motor from a 230v single phase A.C. fan, and I want to use this as a generator. If I machine the rotor to accept strong permanent magnets, and then wire off the 3 coils through 3 seperate bridge recifiers with the outputs connected in parallel (just the dc side)...would this work? I wont be wiring the field coil in, as this is now redundant. This motor originally ran at 1700rpm at 230v, so I figured if this works, I should make enough to charge batteries for my inverters at 100rpm.
Posted: 12:10pm 26 Jan 2007
Yeah that should work, but you may need a little more than 100 RPM. There is a common induction motor conversion called a garbogen, use google to search for "garbogen". Its a common conversion so you should be able to find lots of info to help you.
Mykd
Posted: 04:10pm 18 Feb 2007
thanks for the info, much appreciated!!
