Local Time 00:05 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Concepts on Blade Designs
MrDelanco
Posted: 06:26pm 12 Nov 2011
Common Misconceptions
I have seen many others use propellers. Propellers are used to pull an airplane or push an air-boat or be driven by a motor like in a fan to create wind.
They are not intentionally meant to capture the power of the wind.
This is a common mistake made by many.
It would help to rethink the blade design to allow the wind to power the unit.
Please Post here
Thought's, Idea's, New Blade Design's ;
MrDelanco:Project Videos
It is not only too know what it does but to understand how it does what it does.
Rastus
Posted: 11:26am 13 Nov 2011
Hi MrDelanco,
Welcome to the forum!I'm wondering if it is possible to exstract power out of the nose cone area of a windmill rotor.A propellor type shape would allow the air to flow over/through and when furled may cushion the rotor slow down.What is your opinion?Cheers Rastus
see Rastus graduate advise generously
Tinker
Posted: 02:58pm 13 Nov 2011
  MrDelanco said   Common Misconceptions
Please Post here
So, you are saying that all those gigantic wind generators all over the countryside got it wrong?
You're kidding, right?
Klaus
MrDelanco
Posted: 08:02pm 13 Nov 2011
  Rastus said   Hi MrDelanco,
Hello Rastus;
I may not be understanding your post completely, are you referring to the stream tube affect that travels over the turbine’s rotor, decreases in volume some of the energy so that air flowing out behind it moves even more slowly causing the air behind the turbine hub to slow and expand so new air flowing in would not have anywhere to go? This would allow excessive pressure to build up behind the blades and decrease the efficiency of the propeller type blades.
MrDelanco
Posted: 08:52pm 13 Nov 2011
Hello Tinker;
I am not debating that I do feel there is a better way. I am saying it's time to rethink the blade design for higher efficiency in extracting the power from the wind.
The force in the wind is equal to and opposite the thrust force as the wind passes the rotor and slows down. Then if a larger blade surface area and smaller circumference-diameter can be used to contact that force, a higher efficiency can be extracted from the turbine and lesser wake affect's will be formed behind a wind turbine unit.
I am asking for others thought's and idea's on improving the design of wind turbine blade's on HAWT's or VAWT's to be more efficient in capturing the energy from the wind.
Do you Tinker have any thoughts on new blade design's you would like to share?
Madness
Posted: 09:36pm 13 Nov 2011
A read of this article on efficiency might help.
Wind Turbine design
I am in the process of making some blades that I hope will perform well, the use NACA 2142 airfoil, 3 blades and a TSR of 7. At a 1.3 radius the tips are only 65 mm wide and 7 mm thick. I see others have built similar blades on here and where tested by Glenn and reported to have worked very well.
At the moment I am half way through making the fibreglass mould so can't tell how they will perform but all my research tells me this is the way to go.Edited by Madness 2011-11-15
Posted: 11:29pm 13 Nov 2011
Yes, a propeller is not suitable for a wind turbine. It does work, but not very well. Wind turbines are made differently to propellers, the foil faces the other way.
The 3 blade wind turbine you see used in wind farms is pretty well as good as you can get. They are typically close to 40% efficient, not bad considering they are also designed to run quietly. Slight improvements have been made over the last few years, but only slight, and the people that build the turbines know their stuff. It costs a few hundred thousand dollars to make a big wind turbine, so if they can make them more efficient, they would.
There is also the Betz limit, which is the max theoretical power limit that can be extracted http://www.thebackshed.com/Windmill/articles/WindPower.asp
Rastus the area of the nose cone is very small compared to the whole turbine area. In fact the center 1/3 of a turbine, which is a pretty big hole, only covers 11% of the total area, so a nose cone would be much less, like <5%. So while you could improve its shape to guide the air through the turbine, the gains would be almost unmeasurable. http://www.thebackshed.com/Windmill/articles/SweptAreaofHAWT .asp
MrDelanco
Posted: 01:31am 14 Nov 2011
Hello; I don't know how we got on large turbines.
Could we concentrate on the small home units ?
I see many blade designs out there on small home units.
Do any of you have any thoughts on new blade design's for the small home units, you would like to share ?
Have any of you seen whats out there and have any thoughts on how good or bad they work ?
There are all kinds out there share what you have seen.
mac46
Posted: 02:50am 14 Nov 2011
Hello MrDelanco,
The forum is full of just exactly what you are asking...the folks here have been working on just this topic for several years.
Basicly speaking, the type/style of blade depends on you'r local wind speed, and size/type of generator...among other things such as tower height, obstructions, ect. so we know what you'r asking, but are'nt sure how to answer.
Kind reguards,
Mac46
I'm just a farmer
Rastus
Posted: 01:13pm 14 Nov 2011
Hi Glenn,
Thanks for the reminder about swept area.A passing comment about timber mill blades with twisted trailing edges was "to make the inner blade aproach angle as large as possible,to assist light wind start up".This prompted me to consider exstending it around the nose cone as a helix,to get the last straw to break the camels back.I do accept there is "little" to gain,but done well it could be most of the little bit.As you can see I'm drawing at straws!!Cheers Rastus
Hi Mr Delanco,
Thankyou for your knowledgeable reply.Glenns comment about the Betz law is pertainent to your description.Cheers Rastus
Tinker
Posted: 03:06pm 14 Nov 2011
I see I have a little language problem here. What you call a "propeller" on the front(or back) of an aircraft is in my mind a device that converts rotational energy into thrust.
Now, if the thing is engineered to work in reverse (as on wind mills) and converts wind thrust into rotational energy I still call it a 'propeller'.
You obviously don't so I beg to differ here. I do agree that one can't interchange one application for the other and expect similar efficiency.
Klaus
Eddie
Posted: 01:37am 15 Nov 2011
I can give you my ideal blade for a small home wind generator.after lookimg up everything I could that was written in laymans terms for my small 125 watt turbine I settled on ( I'm talking about pvc) Three blades 19 1/2 inch long cut 7 degrees off the center line towrds the leading edge.This is susposed to make them like a rifle spiral and therefore more effiecient?
So far they have worked better than the original blades that came with it and several other designs I tried.
VK4AYQ
Posted: 11:37pm 15 Nov 2011
Hi All
I notice a lot of different Ideas on turbine blades and increasing their efficiency, also the reference to the commercial giants in wind farms, but I think we need to be more size specific for our size mills as we tend to keep our blades less than 3.5 meters.
Over the last three years I have tried a number of blades and find that they all do a reasonable job, providing there is 5 MS + wind.
I have tried the poly pipe blades both home made and a set I bought from a blade maker, above 5 MS they are OK but leave a lot to be desired. If you are short of funds and want to get something going OK but in reality a trip to Bunnings or a timber supplier of your choice and purchase 3 fence palings round the front edge and taper the back over the last 50% of cord is a better choice.
I have one mill with conventional professional made 3 blades 8 ft diameter for a 1KW mill I refinished and balanced them and they perform well at 7+ MS but not good starters.
I also have a work in progress of a 1 KW mill driven by a set of Gyro copter blades cut down to 12 ft diameter, I will let you know how it goes when finished.
I have also tried multi blade high speed blades from 3 to 10 blade 60 inch dia they start well 2 MS and produce good power above 8 MS but the small diameter limits low down power, I am going to extend the blades by 24 inches and then I think they will be useful.
By far the best blades I have tried are the GEO 222 alloy blades, they are not a high speed design but the torque produced and power capture is outstanding, I have just purchased 3 more sets to add to my mini wind farm, and also a set to make a 8 meter diameter blade for a 5+ KW machine I am gathering parts for.
If you want a set of cheap blades do the fence paling thing and it will run a 500 watt turbine in 5+ MS wind, I wouldn't waste the time making a set of poly pipe blades unless for trial purpose.
Do not make the mistake of comparing our little blades with a large commercial turbine, as that is like comparing a runabout with a ship.
On the center of the blades there is very little power collected so it is possible to extend the center to get more swept area with little or no loss in power extracted as the blade near the center is travelling much slower than the wind speed, and is therefore less effective, this area does have some effect on start up speed.
Sorry to stir the possum in the discussion but this is based on my own testing.
All the best
Bob
Foolin Around
Rastus
Posted: 09:02am 16 Nov 2011
Hi Mr Delanco,
A forum member,Rinaldoparaipan,was very inventive and posted his individaul, concept blades a short while ago.I think most of us rely on more qualified people in this field for help.I get what seems to me,to be a basic idea,then try to develope it with others input.Cheers Rastus
MrDelanco
Posted: 02:19am 17 Nov 2011
Hello: Rastus
Most of the discussing has been about Hawt type blades, with several good points and inventive idea's. I would tend to listen and consider that member's and the other members inventive qualifications in the field and share concepts on improvements and theories with that member and other inventive members that are building and sharing their idea's.
I have done testing and building of several styles and will be sharing ideas on both the Hawt and Vawt as the discussion progresses.
From my testing I favor the vawt style so I can allow the blade's to start strong and stable. Then design a compatible extraction unit to work with the output produced by the blade design and this process will work for both styles.
You really don't know what you have until you build a prototype and do some testing.
The theories of yesterday were developed with the sciences of yesterday.
With the new sciences of today, those past theories may be enhanceable.
Cheers Bob. Edited by MrDelanco 2011-11-18
KiwiJohn
Posted: 07:56am 17 Nov 2011
Hi Bob...
I do not think the theories change very much over a decade or so, oh yes they did change quite rapidly at the end of the century before last but I dont believe much has changed in the last half century. What has greatly changed though is the tools and materials that have become available to us to implement those theories.
Posted: 08:19am 17 Nov 2011
Yeah I agree with John.
HAWT wind turbines today are pretty much unchanged for over 50 years, and thats because they have been engineered to as good as they can get. There are a few laws that dictate how much power we can extract from the wind, and the modern wind turbine is a good balance between performance and economics. There may be a gain of one or two percent in the future, but nothing more. VAWTS are the same, there are different designs popping up every 2nd week, but again there is not going to be any massive jump in performance, because they are already as good as the laws of physics allow. A great deal of research was put into VAWT's in the 70's, most of us are familiar with the egg beater looking Darrieus VAWT's, but in the end, a 3 blade HAWT proved the best commercial design.
Its like the modern aircraft. They basic shape and control hasn't changed since the war. In 70 years little has changed, because its a proven design that works. The engineering done at the beginning of last century is sound, and there is little we can do to improve it. In my lifetime the only noticable change in passenger aircraft is the fitting of a TV screen in the headrest!
Small wind turbines like those we build follow the same rules as their big cousins.
MacGyver
Posted: 08:27am 17 Nov 2011
[Quote=MrDelanco] I see many blade designs out there on small home units. Do any of you have any thoughts on new blade design's for the small home units, you would like to share ?
Welcome to the 4m. Here, try THIS on for size.
. . . . . Mac
Edited by MacGyver 2011-11-18
Copeville, Texas
MrDelanco
Posted: 01:50pm 17 Nov 2011
  MacGyver said   [Quote=MrDelanco] I see many blade designs out there on small home units. Do any of you have any thoughts on new blade design's for the small home units, you would like to share ?
. . . . . Mac
Hello Mac;
Very nice work. I have used a similar material with aluminum cladding but had some whistling from the holes along the edge. How does the Coroflute you used hold up to strong winds and does the material breakdown when exposed to prolong sun-lite ?
Regards Bob.
MrDelanco
Posted: 02:21pm 17 Nov 2011
  KiwiJohn said   Hi Bob...
Hi KiwiJohn
I agree as I stated with the new sciences ie" tools and materials that have become available" today, those past theories may be able to be enhanced.
I do feel that with today's materials available for capturing a driving force from the wind, and modern technology implemented into the Pma's. Betz's theory can be enhanced with the implementation of modern technology "design materials" then wind power could take a big step into this century.
Say for instance one pma being driven by a windmill that is being used to power a 2nd pma built as a motor generator through enhancements in the electrical circuit. Could this allow the 2nd pma to operate at a steady speed even if the wind force slows for a time ?
Cheers Bob.
