Forum Index : Windmills : Non Modifyed F&P - High Voltage Output
| mrpackethead Newbie Joined: 11/11/2006 Location: New ZealandPosts: 17 |
Why is everyone running there F&P's at low voltage? Every thing should be as simple as possible. Not simpler. |
We were just talking about this subject a couple of weeks ago, have a look at this thread http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=400&PN=1 One of the concerns is hight voltage, as in over 500 volts if things go bad. Using high voltage does have its good points, but there would need to be some serious safe guards in place. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
