Forum Index : Windmills : 2000 watt possible??
| MeSoDumm Newbie Joined: 21/07/2011 Location: United StatesPosts: 2 |
If you duplicate your wire coils and magnets on opposite side of wheel spindle would it produce 2000 watts? MeSoDumm |
niall1![]() Senior Member Joined: 20/11/2008 Location: IrelandPosts: 331 |
hi meso 2k seems to be getting into heavy duty terrority...it sounds like your wondering about stacking alts together ?....if so i think its kind of going to require your own machine shop to tool up your own parts......i think some commercial axials are designed that way (modular).... heres a good read on a machine thats capable of producing 2k...it,ll give you a feel for whats involved with building for that kind of power and scale....prop size ,alt and tower.. otherpower 17 foot hope this helps in some way .... niall |
Not to mention you need to upsize the turbine to suit. Stacking alternators will increase the output, but only if you put more power into it. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| windlight Guru Joined: 03/03/2007 Location: AustraliaPosts: 331 |
Chad short answer yes but. all of the above applies read this and come back with more questions. it's on this site Of course you have to be in a good wind area, generally if you get an average of 15% of rated output you are doing well. this is what you mean I think Allan "I like this place and willingly could waste my time in it" - (Act II, Scene IV). |
