Local Time 02:47 25 Oct 2026 Privacy Policy
Forum Index : Windmills : about windmills furling system
Aris
Posted: 03:58pm 13 Nov 2010
in web have explained. about furling system, how “The turbine thrust or force can be worked out with -
Turbine Thrust = Diameter2 * WindSpeed2 / 24”. i’m question is what mean 24 ??? please help me…with detail.thanks….
Edited by Aris 2010-11-15
MacGyver
Posted: 06:54pm 13 Nov 2010
Aris
Welcome to the 4m.
Click this link and read the explanation. The math is in the lower portion.
. . . . . Mac
Copeville, Texas
scoraigwind
Posted: 08:45am 14 Nov 2010
I have to admit that the formula is mine, and the number 24 is intended to give you the answer in kg of thrust. I published several such formulae in the back of my book 'Windpower Workshop' so as to help people make rough design decisions. Although based on theoretical principles, this is not a precise equation but more like a 'rule of thumb' that gives a useful answer.
Various people have taken my design equations and popularised them for example Ed Lenz at windstuffnow.com which is how this formula arrived at the helpful page on this domain http://www.thebackshed.com/Windmill/Docs/Furling.asp which helps you find the right design of tail for a particular situation.
I use the same equations for my own design work but i have also learned to tune them based on experience. I would not use them to two places of decimals and expect a precise result. Often there are many factors at work that make reality different from the theory.
Hugh
Hugh Piggott
Aris
Posted: 09:10am 14 Nov 2010
@MacGyver
i already read that link..
but i still confuse where is the "24" come from in the "turbine thrust" formula??
and any one can help me with free body diagram of this furling system..??
thanks before...Edited by Aris 2010-11-15
scoraigwind
Posted: 09:39am 14 Nov 2010
I got it from the Betz analysis of optimum action on the wind. Speed in the wake should ideally be slowed down to 1/3 of the upstream speed.
Speed through the rotor disk can then be shown to be 2/3 of upstream V.
Thrust force = rate of change of momentum = mass flow rate * change of speed
Mass flow rate is (density)*(Area)*(speed through disk)
= 1.2 * pi/4 * D^2 * 2/3 * V
change of speed is also 2/3 V
So finally the thrust in Newtons is
1.2 * pi/4 * D^2 * 2/3 * V * 2/3 * V
= D^2 * V^2 /2.4 N
= D^2 * V^2 /24 kg
Voila. Rough and ready. 23 might be more accurate to be honest, but this is a rule of thumb, and 24 is easier for mental calcs. Real world data shows that a factor of 30 works better for a lot of machines. But this will depend on tip speed ratio etc. And the centre of thrust is not always at the centre of a skewed rotor anyway.....
I have published plenty of plans for tail furling systems that work well, but other than this equation I have not published a design procedure. You can use the procedure in the above link but take care and allow for some adjustment of the weight of the tail. Also I would recommend angling the tail beyond 90 degrees so that it actively opposes the thrust of the rotor blades and you will hold the rotor closer to facing the wind properly. In other words give the tail vane an angle of attack to the wind when the rotor is squarely facing it.
Hugh Piggott
Posted: 09:51am 14 Nov 2010
The "24" is a constant, recycled maths. It would have been calculated using a combination of air pressure at sea level, imperial to metric units conversion, etc, values that wont change much, or at all. Basically, to save the work of recalculating values that never change, we use recycle old calcualtions, and in this case, use 24 in our maths to represent all the other stuff, other than wind speed and diameter.
Hope that made sense.
There's another example on this post
http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=252.
It uses Force on the turbine = .00492 x area x windspeed^2, same thing, the .00492 is our constant.
Hugh has made an important point to, you can do the maths, but in real life it will perform differently. Furling can be a bit tempermental to set up, and you will usually need to make a few changes in the field to get it right.
petanque don
Posted: 12:32pm 14 Nov 2010
Is it a coincidence that “24” is “42” transposed????
Spooky isn’t it.
Aris
Posted: 12:50pm 14 Nov 2010
how about with free body diagram of this furling system..?? Edited by Aris 2010-11-15
MacGyver
Posted: 07:47pm 14 Nov 2010
[Quote=Aris]Is it a coincidence . . .
I think it interesting to note what Albert Einstein had to say about this; "Coincidence is God in disguise".
Could be true, could be not; a curious thought either way.
. . . . . Mac
Copeville, Texas
powerednut
Posted: 01:02am 15 Nov 2010
= D^2 * V^2 /2.4 N
= D^2 * V^2 /24 kg
*snip*
Thanks for that Hugh - very informative.
Aris
Posted: 03:05pm 15 Nov 2010
oke thanks all....
i have questions again....about pivot angle
i have windmills
my diameter turbine = 1.129 m
so my Turbine Thrust = 21.244 kg
The turbine moment ( torque )= 2.124 kgm
tail weight = 2.893 kg
tail Length = 69.5 cm
So what about the pivot angle results calculation ??
please help me...step by step...thanks....Edited by Aris 2010-11-17
Posted: 09:37pm 15 Nov 2010
You left out the important bit, what speed do you want the tail to start furling?
Remember, the calculations will give you a approximate result, other factors can also affect furling, like alternator loading, changes in air density, etc. Once you have an angle, you might still need to experiment to get it spot on.
Aris
Posted: 05:14pm 16 Nov 2010
@Gizmo....
i want the tail to start furling with speed 20 m/s (72 kmh)too.
help me...
GWatPE
Posted: 09:18pm 16 Nov 2010
Start furling at 20m/s?
This is quite small, almost a windmill ornament size. To start furling at 20m/s, implies fully furled at approx 25m/s. Most windmills fitted with furling, would start furling at under 10m/s.
Check, most commercial windmill of this small size don't bother with furling. The relatively high rpm needed to extract power from these windmills dictates skinny blades. These are usually low torque, and any furling system will be difficult to setup.
For all practical purposes, any calculated parameters will be a guess at best, so extensive in the wind testing will be required.
Gordon.
Edited by GWatPE 2010-11-18
become more energy aware
Aris
Posted: 11:16pm 16 Nov 2010
yes, 20 m/s
please give me solution and results calculation about my pivot angle...
Aris
Posted: 02:41pm 19 Nov 2010
i have questioan again about formula furling system
in furmula have :
Furl resistance = Tail Weight * Sin ( Pivot angle in degrees) * Sin 45
and
Tail pivot angle = Sin^-1 ( Turbine Moment / Tail Length / Sin 45 / Tail weight )
What mean is Sin 45 ??
thank before..... Edited by Aris 2010-11-23
