Local Time 03:00 25 Oct 2026 Privacy Policy
Forum Index : Windmills : American Raptor Blades
joyt12k
Posted: 01:06pm 20 Sep 2010
Hi, has anyone tried the carbon fiber Raptor blades from America on a F&P, they come in 3,5,7,9,and 11 also any views on their PMA?
jasmine
VK4AYQ
Posted: 01:29pm 20 Sep 2010
Hi Jasmine
I have a few sets I tried, from 3 to 11 blades and found that they are very effective in over 8 ms winds but below 6 ms they are pretty useless unless the generator is 200 watts or less. They are quiet and smooth running after you trim the blades and balance them.
I plan to use them on 600 watt non furling machines, and that's the reason of getting a few to try, the 5 blade is the minimum that works on those, with the 11 blade a bit better. they will run up to 2000 rpm which is what I wanted.
For the F&P you would need the 11 blade I think, as the starting torque is low on the lesser blade sets and it doesn't spin as fast but maybe still to fast for the F&P.
I haven,t used their alternator PMA type but found that automotive alternators in general need more rpm than wind turbine blades are capable of delivering, one 65 amp 12 volt unit PMA I tried needed 3500 rpm to get any useful out put an 5500 to get 45 amps.
All the best
Bob
Foolin Around
joyt12k
Posted: 08:49am 21 Sep 2010
Hi Bob, I have just bought seven blades with the hub, I can always buy more, they were $21.00 ea and $15.00 for postage, very reasonable. Will try them out as soon as they arrive.
Do you happen to know why their PMA mills and blades are designed without furling?
jasmine
dwyer
Posted: 11:02am 21 Sep 2010
Hi Joyt12k
They have solid state electronic regulater just like normal automotive alternators so no need furling
Dwyer the bushman
VK4AYQ
Posted: 11:22am 21 Sep 2010
Hi Jazmine
The PMA works at much higher RPM than other alternators so the high speed blades are a good driver and no need to furl as the alternator can work faster than the blades can go.
That is the combination I am putting together as I dont like furling, have a look at Karls latest post and you will see the results of constant furling.
All the best
Bob
Foolin Around
joyt12k
Posted: 01:41pm 21 Sep 2010
Thanks Bob, looks like the way to go, if these blades don't work with my F&P I'll be buying one of their PMA's.
I'm looking to achieve around 18 amps, don't suppose you know what rpm roughly
would be needed? Have seen their graph but would prefer hearing from someone whose tried it.
jasmine
VK4AYQ
Posted: 09:36pm 21 Sep 2010
Hi Jasmine
I haven't tried one of their alternators as the one I had was one off a tractor, it needed a lot more rpm than they state for their conversion, I was going to get one of theirs to try but didn't get around to doing it, to many projects on the go ,and I decided to get one of Phills lower speed machines as that suits my wind speed at this location better.
A friend of mine got one with a six blade but due to the small diameter it takes a strong wind to get 30 amps at 12 volt. He hasn't got a wind speed for me, but I think it is like mine and is above 8 ms.
If you have that kind of wind then they will perform but if you have lower speed you would be better off with a larger diameter 2.5 to 2.8 meter. Have a look at Altons chart of propellers for an indication
http://www.alton-moore.net/wind_calculations.php
It wont work with the high speed blades like Raptor but is a good indicator on slow blades.
All the best
Bob
Foolin Around
joyt12k
Posted: 01:11am 02 Oct 2010
I've given up with the F&P for now and have just bought the Super Victory PMA.
They recomended the 24v 1500watt one to achieve what I want, that is between 15 to 20amps at around 300RMM, if higher I would be more than happy. The 7 blades should arrive middle of next week so I'll try them on the F&P, somehow I have my doubts that's why I bought their PMA. Will keep you all posted.
jasmine
joyt12k
Posted: 11:35pm 08 Oct 2010
Looks like the postal service in the States is crap, it's been 3 weeks, and still waiting for delivery of my blades, as for the PMA that's been a week since odering
and they hav'nt posted it yet.
jasmine
VK4AYQ
Posted: 11:57pm 08 Oct 2010
Hi Jasmine
I have found that it takes a month to get things from the USA so don't dispare.
I will be very interested on your results with the Raptor blades and the PMA 24 volt unit,
All the best
Bob
Foolin Around
