Local Time 03:27 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Using Alton’s Blade Calculator
MacGyver
Posted: 04:36am 06 Sep 2010
Crew
Does anyone have any experience using Alton's Blade Calculator with blade stand-offs?
What I mean by 'stand-off' is merely extending the blade spar out from center, which means at the hub area, there are only posts sticking out into the breeze with the respective blade root not actually coming into play for whatever distance it is held off the hub.
I'm wondering if there's more the amount of power one can extract from a given blade diameter than meets the eye and if there is any "threshold" blade surface necessary or if one could fly a tiny blade ten feet out on a tube and have a functional 20-foot diameter prop.
My hunch is it wouldn't work that easily, but I don't really know why.
Just curious.
. . . . . . Mac Edited by MacGyver 2010-09-07
Copeville, Texas
Posted: 05:37am 06 Sep 2010
From what i understand the starting torque is generated by in near the hub and the blade speed is generated out at the tips, so it is a balance of the two areas to give best results without causing excess drag.
So your theory of a tiny blade out on the tip of a pole would have huge problems with getting started but once (if) going would spin fast.
Pete.
VK4AYQ
Posted: 06:10am 06 Sep 2010
Hi Mack
On a turbine most of the power is generated on the outer 30% of the blade so to a point, extending the blade further out will help, but it does cause the blade to run slower as the tip speed ratio is trying to increase, this depends a lot on the blade design as fast blades have optimized airfoil sections, not so easy to reproduce in our home made designs.
There is also another factor that comes into play and that is the Reynolds number of the combination, this is a relationship of the cord of the blade and the airspeed of the blade at its optimum TSR. This governs the lift produced by the airfoil, and that in turn gives the torque produced by the blade, this is also another reason why the outer portion of the blade does the most work as it has a higher Reynolds number. As Pete said the inner part is to get it going and the outer part does the work.
As most of our blades operate over a wide range of speeds, the trick is to use the best mid speed blade as the speed increases there is power to burn so no need to optimize the top end unless you are a wind farm developer.
All the best
Bob
Foolin Around
aorn318
Posted: 02:59pm 06 Sep 2010
Hi Mac
only new here but i had a read of the "understanding swept area" in projects and information not sure if its what your looking for but it shows how the blades operate and where they generate what % of power
Aron
If it ain't broke don't fix it
MacGyver
Posted: 05:36pm 06 Sep 2010
[Quote=VK4AYQ] . . . the outer portion of the blade does the most work as it has a higher Reynolds number.
Hmmm . . . I thought it was the other way around.
I always thought that had to do with surface area and I purposely reduce the Reynolds number on my blade tips by tapering each blade from the root to the tip, thinking the relative speed is greater at the tip and a higher R # means more drag.
Do I have it wrong? If I do, it wouldn't be the first time I've goofed up the engineering, by the way.
. . . . . Mac
Edited by MacGyver 2010-09-08
Copeville, Texas
niall1
Posted: 11:16pm 06 Sep 2010
hi Mac
a while back i did try Altons calculator ...(apart from the ideal big root angle) i,m not sure if you mean extending the blades or eliminating the inner section ...
i think if the roots were trimmed a bit and blade extenders were used the drop angles at each station would be confused a bit ..the tsr would be different as was mentioned before and the blade sections wouldn't be as well matched to the swept area they rotate through
...plus you'd miss out on a nice big mounting area to secure them together and onto an alt Edited by niall1 2010-09-08
niall
Posted: 11:52am 07 Sep 2010
This is the page Aron was refering to.
http://www.thebackshed.com/windmill/articles/SweptAreaofHAWT .asp
Basically, the inner 1/3 of the blade is only making 10% of your power, and the outer 1/3 is making over 50%. Your better off extending the blades out slightly than spending too much time on the inner 1/3 of the blade.
ps. Nice set of blades there naillEdited by Gizmo 2010-09-08
VK4AYQ
Posted: 06:18am 08 Sep 2010
Hi Mack
The higher the Reynolds number the greater the lift from the airfoil relative to its size so for our application we want torque to drive the generator so it a bit opposite to an aircraft that operates its airfoils at a much lower coefficient of lift to reduce the drag whereas we operate ours at a higher coefficient of lift to increase the rotational torque to extract power from the wind.
A twisted blade as in the Alton calculator, that is more pitch accurate over the blade length is theoretically better but due to the reduced cord at the tip it doesn't produce as much torque at slow speeds, this kind of blade is designed for better high speed efficiency. The blades I am using on the new mill arn't twisted to compensate so will be less efficient at high speed but better at low speed and that's where our mills operate most of the time. Its all a compromise as our application is opposite to the use as in aircraft propeller design as a lot of wind turbines are based on.
All the best
Bob
Foolin Around
VK4AYQ
Posted: 10:30am 08 Sep 2010
Hi Mack
Just had a look at Altons calculator and compared it to the non twisted blade on my new mill.
If you enter 2.8 meter diameter TSR 7 Angle of attack 8 and a coefficient of lift at .8 as that corresponds to the CL of .8 for a Clark Y airfoil section and then look at the carving table angle at each station you will find that the outer four stations are negative angles of attack this corresponds to a lower CL and less power being produced at these stations, this translates to lower torque to the generator compared to a fixed angle of attack of a non twisted blade. The non twisted suffers the effect in reverse as the AA decreases in efficiency as you go closer to the center, a compromise for sure but on slow speed turbines like ours it fills the bill. On huge power generating wind farm machines the blades are designed for the maximum power absorbency over the disk area, this sort of technology is beyond the scope of our small turbines.
The blades on my turbine are designed specifically for low speed high lift with a CL in excess of 1 at eight degrees AA and this goes right to the tip of the blade so the force acting through the hub has a greater moment arm for the wind energy absorbed, and so generates more torque, which in turn means more power out of the alternator.
It also demonstrated that Altons calculator isnt an absolute for all types of blades but a good indication of energy available within the disk area.
All the best
Bob
Foolin Around
