Local Time 03:14 25 Oct 2026 Privacy Policy
Forum Index : Windmills : windmill on ebay
arklan
Posted: 02:38pm 05 Sep 2010
http://cgi.ebay.com.au/250W-Vertical-Wind-Axis-Turbine-/1904 37549656?pt=AU_Solar&hash=item2c56f66658
heres a strange one, what do u think guys?
Posted: 04:24pm 05 Sep 2010
I think the link is broken
Pete.
ProTow
Posted: 06:18pm 05 Sep 2010
go to ebay and put this in there to pull it up.
that worked for me
If it works the First time You did something Wrong.
RossW
Posted: 09:49pm 05 Sep 2010
Well, first thing that strikes me is someone doesn't seem to understand what "vertical axis" turbines are. That looks a lot like HAWT to me :)
Also looks hellish expensive for what it is. Still, they say there's a sucker born a minute, so someone will likely fall for it.
VK4AYQ
Posted: 03:44am 06 Sep 2010
Hi Ross
They might be referring to the fact that it stands vertical rather than laying on the ground, I looked at the specs and it is only 1 meter in diameter so would need a gale to get it working, also looks a bit flimsy, I see it is posted by a ladder company, that may explain something.
All the best
Bob
Foolin Around
Ghetto
Posted: 07:36am 06 Sep 2010
I've seen that one for a while on ebay now. As far as I'm concerned its a HAWT, and it made me smile at the time cause what were they thinking calling it a VAWT?
Do shrouded HAWTS have increased efficiency? I'm think more about the turbine type designs where the shroud is a lot deeper making more of a wind tunnel type effect.
+1 on Ross said, its too expensive for its output.
Cheers,
RobEdited by Ghetto 2010-09-07
arklan
Posted: 09:42am 06 Sep 2010
the shroud wouldnt help at all coz its downwind, and the shroud is downwind of the downwind :p
VK4AYQ
Posted: 12:43pm 06 Sep 2010
Hi All
The shroud may create a low pressure behind the blades and augment the airflow that way but all said its a novelty for the front garden.
All the best
Bob
Foolin Around
