Local Time 20:55 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Working out Watt Hours
Posted: 11:39pm 13 Sep 2006
I want to add a Watt Hours display to the PicLog software. But not sure which way i should go about this.
I know if the windmill made 10 watts for 1 hour ( or 5 watts for 2 hours ), it made 10 watt hours, how should I calculate a watt hour figure for something that varies so much. If the PicLog recorded every 60 seconds, and the values jumped around between 0 to 25 watts, how would I work out watt hours for that hour, or day?
Would I add all the recordings for the day, then divide that by the number of recordings in the loggin period ( 3600 for a full day ) then multiply that by 60 to get our full hour?
I think I'm off the track a bit here.
Glenn Edited by Gizmo 2006-09-15
RossW
Posted: 04:20am 14 Sep 2006
Glenn, watts are an instantaneous measure, expressed conveniently in units like watt-hour, kilowatt-hour etc, but absolutely just as reasonable in watt-seconds.
I built a controller some years ago that did exactly that - measured instantaneous power every second and accumulated to provide:
total watt-hours in
total watt-hours out
nett watt-hours (in-out)
If you add the watts every second, then divide the answer by 3600 (seconds in an hour) you get watt-hours.
If you only take a measurement every minute, you're going to be moderately inaccurate - but it might be good enough for the purposes. The more samples you take, the closer you will be to the actual value. (I believe some of the NiMH "smart packs" have an 8 MIPS processor and sample power in and out at least 1000 times a second)
Oh, and if you are logging every minute, there are only 1,440 minutes in a day (86,400 seconds), not 3600. (That's how many seconds in an hour)
RossWEdited by RossW 2006-09-15
Xcat
Posted: 11:24am 14 Sep 2006
Gizmo, I haven't looked at your PICLOG so I will just write in terms of algorithms. I am presuming you are calculating watts by sampling voltage and current and multiplying the corresponding samples. After that establishing the quantum of watt-hours simply becomes an integration exercise. In the digital world there is a trade-off between accuracy and sampling frequency. The main issue that affects this trade-off is inertia of the system being sampled. Basically this is the rate of change of the system output. If the rate of change is low then the sampling frequency can be lengthened without the risk of missing a change in the output.
In your example you have set the sampling frequency at 60 seconds. This may be too long (gut feel) for a windmill in gusty conditions. My feeling is that 15 seconds may be nearer the mark for inertia of such a system.
So in pseudo code, try this:
Inner loop (sample frequency 15 seconds)
get volts (from ADC channel)
get amps (from ADC channel)
watts = volts * amps * 15
add to watt-hour accumulator
hour timer flag set? go to outer loop
wait for the next 15 second tick (or do something else by returning from interupt service routine
Go to Inner loop
outer loop (executed once per hour)
reset hour timer flag
reset seconds time flag
store watt-hour accumulator in log_array{1} +1
store time_stamp in log_array{2} +1 (assumes presence of real time clock)
increment log_array index counter
inner loop time flag set? go to inner loop
wait until inner loop need to start or do something else
This should end up with an array log of watt hours that you can download or spit out to something else as needed. Using a real-time clock to trigger a couple of interrupt service routines will leave a good chunk of computing power to do other things in the meantime.
HTH
Xcat
Brisbane QZ
Posted: 11:44am 14 Sep 2006
Thanks for that guys, I now know exactly what I need to do.
I will post an update on the Piclog this weekend with the updated software.
Thanks again.
