Local Time 20:55 24 Oct 2026 Privacy Policy
Forum Index : Windmills : air-lift pump thingy
AllanS
Posted: 04:09am 13 Sep 2006
Dwyer mentioned air-lift pumps. I've been thinking of using these as a way of squeezing some energy out of low grade heat.
As the compressed air and water rises up the pump pipe, the bubbles expand, lifting the water. But what if it was hot water, heated by cheap solar panels? This would give you maybe 20% extra expansion, lifting the water even higher. Then run this water down a pipe thru a pelton wheel. This wheel not only makes the compressed air to drive the lift-pump, but also makes a bit of electricity.
I don't know if inefficiencies would kill this device (do air-lift pumps give much bang for the buck?) but it's a neat idea, nonetheless.
RossW
Posted: 08:54am 13 Sep 2006
  AllanS said   Dwyer mentioned air-lift pumps. I've been thinking of using these as a way of squeezing some energy out of low grade heat.
Are you saying "over-unity" systems? I hope not :)
If the pelton wheel is making the compressed air to lift the water to drive the wheel.... well, it just ain't gunna work unless something gives more energy out than it uses!
AllanS
Posted: 09:13am 13 Sep 2006
Hi Ross,
No over-unity dreaming here. The isothermal expansion of the gas (taking heat out of the water) does useful work, lifting the water higher than by the expansion of the compressed air alone. But how much higher, that's the question. High enough to compensate for the lift-pumps inefficiency? I somehow doubt it.
Here's a natural lift-pump that makes fascinating reading.Edited by AllanS 2006-09-14
