Local Time 04:19 25 Oct 2026 Privacy Policy
Forum Index : Windmills : vawt on ebay
jamiec
Posted: 02:41pm 10 May 2010
Hi just wondering if anyone knows anything about this vawt for sale on ebay
http://cgi.ebay.com.au/12v-50Watt-Vertical-Axis-Wind-Turbine -/270576835884?cmd=ViewItem&pt=AU_Solar&hash=item3effa2dd2c
was hoping it may be something usefull to get started with.
thanks
jamie
wind-pirate
Posted: 03:06pm 10 May 2010
Hi Jamiec
12 volts, 50 watts... Not very much, About 4 Amps
You could charge batteries, but it would take a quite a lot of time.
I can't make the link work.
Might make a Good learning turbine. If cheap enough.
Ron
THE Pirate.
stealing wind & solar energy is fun
Poss
Posted: 07:01pm 10 May 2010
Same as Jaycar unit CAT. NO. MG4570 check it out on web site www.jaycar.com.au but money could be better spent elsewhere
A brave man may not live for long, but a careful man does not live at all.
dwyer
Posted: 10:44pm 10 May 2010
Have seen this before as how long this will last out in this weather maybe 6 months Ok if you make at bid if is under $5 plus postage cost but money could be better spent elsewhere
Dwyer
Posted: 11:08pm 10 May 2010
Here's the link...
VK4AYQ
Posted: 02:01pm 11 May 2010
Hi all
It would be handy to take camping if near the beach as there is wind there most times, the price is a bit much though.
Makes you think of a set of blades on a F& P probably get double the output for half the price.
All the best
Bob
Foolin Around
MacGyver
Posted: 10:00pm 11 May 2010
jamiec
Gizmo had a link somewhere on the home page showing his using a stepper motor with a small savonius or something similar. I'd look into building something like that before I plopped down that amount of $! At least you would be starting with something that has been measured, whereas this thing on ebay may turn out to be a hoax.
I'll try and find the link and come back here and edit it into place for you.
Edit: Okay, I think this is it. Glen, correct me if I'm wrong.
LINK It's the picture in the lower-right-hand side of the page. There used to be an article about it on here somewhere!
. . . . . MacEdited by MacGyver 2010-05-13
Copeville, Texas
