Local Time 04:20 25 Oct 2026 Privacy Policy
Forum Index : Windmills : generator from E-motor
MagusWake
Posted: 01:13pm 21 Apr 2010
How do turn an electric motor into a generator? seen it in popular mechanics!
MagusWake
Posted: 02:46pm 21 Apr 2010
Hi MagusWake
Welcome to the forum.
Is there something missing from your post above, or are you asking a question or what, as i dont follow what it is you are reffering to.
Pete.
VK4AYQ
Posted: 02:58pm 21 Apr 2010
Hi Magus
In the past I have used a 3 phase motor as an alternator by connecting AC caps across the windings and that induces an excitation into the windings DC superimposed on the AC, it did work but wasn't very stable voltage wise and took a spark up to start it working, it was in an old book I had and I think the caps I had weren't the right value. I have seen a commercial alternator using this method it had 3 caps in the terminal box, but no value markings. When it loads up it becomes more stable.
All the best
Bob
Foolin Around
Posted: 08:19am 22 Apr 2010
Hi Magus
Yes we're going to need a lot more infomation. You question is like asking how long a piece of string is.
There are many different types of electric motors, some can be used as alternators, some as generators, and some wont work as anything other than a motor. We would need to kow what sort of motor it is before giving a answer.
What did you want to use the motor for?
Bryan1
Posted: 09:53am 22 Apr 2010
These days we should be consulting our esteemed Chinese guru 'How Long' to answer this thread.......
