Local Time 21:08 24 Oct 2026 Privacy Policy
Forum Index : Windmills : windmill
makourain
Posted: 07:27am 18 Aug 2006
i got my second windmill up and in the wind. its a hawt.
for some reason it sometimes spins around like a vawt :s
the wind changes a fair bit here, but the tail is also a bit curvy.
could the tail fin be acting like a savonius?
it seems to change wind direction more than the minimill and not always in the same direction.
but it is 2 metres higher than the minimill.
thoughts?
Posted: 08:47am 18 Aug 2006
May need a bigger tail? A curved tail or tail with a bend in it would be ok so long as its big enough. Is it easy to make a bigger tail, or more the tail further away from the windmill?
If you can, post a photo or drawing of the tail with some basic measurements.
A tail thats too big is ok, but one thats too small will be trouble.
makourain
Posted: 04:20am 22 Aug 2006
the tail is fine, i discovered its the minimill thats the problem, its a bit stiff.
winds of 80kph+ here today, broke both my mills
