Local Time 04:59 25 Oct 2026 Privacy Policy
Forum Index : Windmills : wincharger
DTV004
Posted: 05:37am 25 Mar 2010
old wincharger up and working the original blades are in the garage i have trouble to balance the blades so i make a 4 blades of 1/2 inch thick from a PVC ...a video on you tube ...http://www.youtube.com/watch?v=bAstMCQ1nFk
KarlJ
Posted: 03:58pm 25 Mar 2010
great stuff, I like the tower too, simple and rugged.
DTV004
Posted: 04:08pm 26 Mar 2010
hi to all. my bank setup is 3 railway battery's. 8volt's 565Ha each, so now i have two 12v 846ha each, so the total will be 12v 1695 ha, so the question is do i need to make 2 battery bank. or one because my windcharger have a hart time to charge all as one . maybe i need a controller to keep charging one bank at the time ? help
Posted: 04:57pm 26 Mar 2010
What was the meter showing Volts or Amps?
Pete.
DTV004
Posted: 05:11pm 26 Mar 2010
volts i will make other video how i setup the battery's
MacGyver
Posted: 05:06am 27 Mar 2010
DTV004
I like your video; good job.
. . . . . Mac
Copeville, Texas
Posted: 06:08am 27 Mar 2010
I would expect at the voltage shown the mill would not have reached cutin.
A amp meter would be a handy investment as this will show what is going into the batteries.
Voltage dont tell you to much except if you are over charging or you batteries are flat.
Overall nice work.
Pete.
DTV004
Posted: 06:50am 27 Mar 2010
thank you. to all one day i will have all working the way suppose to work sorry for my language not perfect....ok this is the video the take long time to upload, by the way i have one amp meter but i don't know how to install ...http://www.youtube.com/watch?v=F8nxsaUC7MkEdited by DTV004 2010-03-28
Posted: 10:13am 27 Mar 2010
Hi DTV004
Can you post some details or a photo of your amp meter as it is very easy to install the meter.
Basically you cut one wire to the battery and install it in series with the battery wire.
There is a few different types so if you can post something on your meter we can tell you how and what to connect to where.
Very easy.
Pete.
DTV004
Posted: 03:23pm 27 Mar 2010
hey i have a 24v battery from a forklift no use for the battery. she hold the charge ...its heavy for free
