Local Time 05:24 25 Oct 2026 Privacy Policy
Forum Index : Windmills : 48 volt 2kw switching to 12 volt
Darren
Posted: 12:50pm 01 Mar 2010
Hi Guys I have a 48 volt wind generator and my inverter is 12 volt.
I was going to wire up some switches so that I can change batteries from 12 volt connection to 48 volt connection.
Will this do any damage if windgenerator was connected to the bank of batteries when it was only 12 volt?
The inverter realy only gets used 1 day per week where the generator will be hooked to 12 volt for the day.
Darren
oztules
Posted: 10:52pm 01 Mar 2010
It should not hurt the alternator.
But it will be hardly worth hooking the thing up, as it should stall heavily and produce almost no power at 12v. Your asking the blades to produce power at 1/4 the normal TSR.... maybe the first few amps, then you will need a gale to do much better. It will also depend on the internal resistance of your stator.... but should be very very tame.
..........oztules
Darren
Posted: 09:57am 02 Mar 2010
Thanks OZ
Thats what I will do then for now till get a 48 Volt inverter.
Darren
