Local Time 06:17 25 Oct 2026 Privacy Policy
Forum Index : Windmills : ac motors
zippy998
Posted: 10:14pm 16 Dec 2009
need some help on this one folks i can get my hands on loads of 240v ac motors the big question is ? can i use it and if i do will i get 240v out of it, @ the right rotation speed or do i have to modify anything although i have fabricating skills my sparky skills are not up to scratch in this field. any diagrams would be helpful as i can read schematics
many thanks
zipps.
birdhouse
Posted: 04:22am 17 Dec 2009
zip-
if you don't want to glue magnets and wind coils, or scrap together an old washing machine you're best off looking for 3 phase ac PM motors. pacific scientific and fanuc and others make em. look for high volts and low rpm. high amps too! so a say 1200 rpm 150 volt 12 amp would be a great start to build a mill to get your electrical legs on. these would obviously go to three rectifiears. if you find one in a shop, short two or all three wires together. the shaft should be hard to turn now.
good luck!
read more and have more educated questions, and the much more brilliant memebers than i of this forum will have better answers for you!
birdhouse
i pee more than once before flushing, and don't have to flush at all up at the ranch!
Dupa
Posted: 03:47pm 17 Dec 2009
Lots of servo motors here.
http://www.hgrindustrialsurplus.com/sub/search_results.aspx? k=1&searchKeyword=servo%20motor&searchCategory=&sortExpressi on=&sortASC=&pageSize=&searchMethod=keyword
I is a injenear
