Forum Index : Windmills : Hello to all
| andy Newbie Joined: 27/05/2006 Location: United StatesPosts: 5 |
Maybe this is not the correct forum to ask if someone knows or have any plans to build a control remote lawnmower. like the one on this website. http://www.gizmodo.com/gadgets/home/remote-control-lawn-mowe r-116553.php Thank you for your comments Andy. |
| Chris Senior Member Joined: 12/09/2005 Location: AustraliaPosts: 146 |
Id say you want a website like this: http://scooters.tziworld.com/ Ask the guys there, they will be alot more helpful then the people on this website since this place is primarily about windmills. |
I did think about converting the ride on lawn mower to remote control, but I figured you would really need to walk around behind it to make sure its cutting a good line. So I may as well sit on it and drive it manually
Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| makourain Senior Member Joined: 19/04/2006 Location: Posts: 111 |
you could probably program something like what you have for your cnc router to control the mower, that way it will automatically go up and down and in straight lines :D |
Thank you for your opinions. As always good source of information Andy |
