Forum Index : Windmills : Where to buy Windmill Blades
| mark30504 Newbie Joined: 10/11/2009 Location: United StatesPosts: 1 |
Hello Our company is doing a project for a customer that need a windmill style blade. We need about a 13 foot dia. blade assembly. Where is a cost effective place to by these ? We do not have the time to manufacture it. Also the wind speed of our customer is quite high, 55mph Should we be looking at a certian type of blade angle or surface area ? thanks for any input. mark |
Hi Mark. Need a bit more info. What is the windmill powering? Will you need a low speed high torque turbine, to pump water, or a high speed turbine for power generation. 55MPH is very fast. Is that a constant speed or peak. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Clarasonic Newbie Joined: 26/11/2009 Location: United StatesPosts: 2 |
Please research ROHACELL as a possible material for making strong \ light weight blades which can take extreme temperatures. ROHACELL has the ability to be formed and bonded to many common materials. More details can be found at www.Clarasonic.com Clarasonic - Distributor of Rohacell a light weigth \ dense cell composite PMI foam which could be used for windmill blades. www.Clarasonic.com |
