Forum Index : Windmills : Big and Bigger
| imsmooth Senior Member Joined: 07/02/2008 Location: United StatesPosts: 214 |
I have a 10.5' rotor. The tower is 3" OD. Cables are 3/16" and the top is 1/4". What size cables and diameter tubing do people here have for something close to 12' diameter? |
Wound need some more infomation to give an idea, but even then it depends if you need to get the tower engineer approved or just want to chance it. How high, and how heavy is the turbine/alternator, etc. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| windlight Guru Joined: 03/03/2007 Location: AustraliaPosts: 331 |
What is the ground conditions? How many or what spacing guys are you planning? allan "I like this place and willingly could waste my time in it" - (Act II, Scene IV). |
