Forum Index : Windmills : New PVC blades
| windie-butt Newbie Joined: 20/09/2009 Location: AustraliaPosts: 6 |
Hi everyone, just signed up to this forum & I'd like to say what a great site the backshed is. Having being inspired by the people on this website I have just obtained 4 x FP motors of varying age from council cleanups recently & would like to build my first windmills. I tried emailing the guy selling the PVC blades via this website but have had no responses for over a month now. Does he still sell them?
Keep up the good work everyone. Paul. |
| Jarbar Senior Member Joined: 03/02/2008 Location: AustraliaPosts: 225 |
Hello Paul, yes the blades are still available not sure where your request went? Please try again. Anthony. "Creativity is detirmined by the way you hold your tounge".My Father "Your generation will have to correct the problems made by mine".My Grandfather. |
Hi Paul Did you use the form on the Anthony's PVC blade order page? There was a bug in there a little while ago and it may not have sent your message to him. I just tested it then and it apears to be working, but I'll keep an eye on it. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Hi Guys, I have tried over the last month probably about 6-7 times but no response via the backshed website. I even tried yesterday. I have tried from a work email & home but no luck. I used the order form on the backshed website. I even got through the "how many" test and proceeded through but no response. Thanks for the quick response guys. I'll try again now. Paul. |
Ok Anthony, I have just sent through an order for 6 blades @ 1.0M with end caps, clockwise rotation. Hopefully it makes it as I got to the end again through your order form saying that you will contact to confirm order/payment. Paul. |
I can see that message has gone through. Sorry guys but it looks like I may have broken that order page when I was doing some updates a few weeks back. Its all working now. My fault. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
No worries Glen. Do you want me to re-send the order? |
Nah its fine, it went through. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
AMACK![]() Senior Member Joined: 31/05/2009 Location: AustraliaPosts: 184 |
Paul Blades work very well and quite too. You will like them.. I did and do. Ten times better the cutting them out your self, tried that too not good. Andy *Note to self 1. Make it thick 2.Make it heavy. 3.Make it stronger than it should be. 4. Don't rush the first job as the second job will cost more and take mor |
Hi Andy, glad to hear the blades work well. I'm hearing you, I think I would fail trying to make my own blades & the time to do them. The PVC idea is great. It would be better again if they could be made from a PVC free type of recycled plastic but it's a great option for people having a go at DIY. And should get more people attempting these FP windmills All credit to Anthony for offering this option to people. Paul. |
| gpalterpower Senior Member Joined: 19/07/2009 Location: AustraliaPosts: 177 |
Hi all , I think there still may be some bugs in the system as I have tried a few time to contact Jarbar about purchasing some blades. Ill try again and see what happens. If no workie can I contact you some other way Anthony. regards Marcus. if it aint broke dont fix it!! |
