Local Time 07:10 25 Oct 2026 Privacy Policy
Forum Index : Windmills : VAWT Question
MacGyver
Posted: 05:44am 11 Sep 2009
Has anyone tried or does anyone know about using a VAWT and
embedding PMs in the base of the thing so they swing past a coil and
establish something on the order of a "passive" 12-volt battery charger or
am I dreaming?
I was thinking of something on the order of a "pulse" charge where the
windmill would pick up speed between passes by the pick-up coil.
I've built many VAWTs for fun, just because they're so simple and fun to
watch spin, but I've never actually tried to make them "do" anything other
than spin.
The more I think about this, the more I think it might just get hung up on
the pick-up coil, eh? Maybe I should design a VAWT that winds up a
main spring, then lets it go for some high-speed action down at the
generator.
Any thoughts?
Copeville, Texas
GWatPE
Posted: 05:51am 11 Sep 2009
The advertising sign type are fun to watch. As soon as you try and produce electricity, they don't do much at all. They are a bit like the whirlygig type type for roof mounts. They are really good for sucking hot air from a roof, but do little as a generator.
Gordon.
become more energy aware
MacGyver
Posted: 06:01am 11 Sep 2009
GWatPE
I was actually thinking of using a design similar to the advertising signs
(a bit larger) and attaching the main shaft to a worm and down-gear to
wind up a big nasty spring.
Once the spring got to some pre-set tension, I'd make an escapement
mechanism that would apply it against a small generator. This would
create a charge only intermittently, thus the "passivity" noted above.
Then again, it may turn out to be just more shop time logged on the
lathe, eh?
Copeville, Texas
