Forum Index : Windmills : helical darrieus
| AllanS Regular Member Joined: 05/06/2006 Location: Posts: 67 |
Great site, folks. How's this for an idea? Get a 44 gallon drum. Use a bit of string to mark out two 15cm wide vanes, spiraling symmetrically from the top of the drum on one side to the bottom of the drum on the other. Cut out the waste. Cut a single slit lengthwise down the side of some inch polypipe and slip this over the leading edge of each vane. Wrap cotton bandage tightly from the polypipe to the trailing edge of the steel vane. This will create a helical airfoil. Saturate the cotton with fibreglass resin. Find the centres of the drum top and bottom, whack on some bearings, do a bit of balancing, and Bob's your Auntie. Watcha reckon then? (The airfoil shape wouldn't be optimal but it might work. It would be better to glue some styrofoam to both sides of the vane and rasp it to shape, but this would take a bit longer. Another possibility would be to cut some styrofoam into 15cm wide strips, run them under a hot wire to get the shape and glue this onto the steel front and back.) |
| makourain Senior Member Joined: 19/04/2006 Location: Posts: 111 |
what you said made no sense |
I worked it out...
Looking down from top, this shows how Allan gets the aerofoil shape. Not shown is the twist, but the windmill sort of looks like a barber pole from the side, sprial shape. The spiral means the windmill is making even power as it rotates, where a straight wing darrious has torque pulses as it rotates. Its a good idea, would be simple to make. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Hey Makourain, And I thought that description was a regular piece of literature! Glenn's drawing makes it clear. I'm 2000 miles from my (very nice) workshop or I'd try it myself. I thought I'd make one today out of a plastic bucket and some hose to see if it works, but I've got distracted. Cheers |
| KiwiJohn Guru Joined: 01/12/2005 Location: New ZealandPosts: 691 |
Sounds great, I think it might be best to fit the bearings and axle first up as the whole thing is going to get really floppy when you 'cut out the waste'. Bandage and resin is a good idea and you could fill the blades with 'No More Gaps' once the resin hardens. Great idea. |
(removed those gargantuan pics) Well, it's not the most beautiful thing I've ever made, but it gives you the idea. (Please note the patented tomato-stick axle.) Now when my wife comes home from shopping, I'll give it a whirl out the car window. |
Whoa! What's with the size of those photos? |
| whirlybird Newbie Joined: 08/02/2006 Location: Posts: 27 |
yeh bloody pics are a bit large mate the dial up crew will not thank you. If anyone wants to try this and I have you will find the ratio diameter to height is important it is 3 to 1. if base is 300mm then height must be min 900mm 3 helices are better than 2 got to Google and type in Gorban Goralov you will find some interesting info there Have fun Whirlybird. I am because I am.I am not always right but often I am. |
Hey Whirlybird. I tried a search for Gorban Goralov but it came up with nothing, are you sure that spelling is right? Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Hi whirlybird, So how did yours go? My bucket-turbine was something of a failure, which was hardly surprising. Any pictures? Gorlov turbine http://www.commondreams.org/headlines01/0517-05.htm |
