Forum Index : Windmills : dual fp setup
| makourain Senior Member Joined: 19/04/2006 Location: Posts: 111 |
i can see you have a dual fp windmill head and iv read comments about them. i cant find on your site a write up about it, so if there isnt one could you do a write up about it? its something im very interested in
thanks |
Hi Makourain I had planned to do a write up about the dual stator build, but life got in the way and its been crazy since then. The dual stator is still up and running, now with the PVC extruded blades. These links might help. http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=744&PN=1 http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=749 http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=751&PN=1 Fitting the new blades http://www.thebackshed.com/windmill/forum1/forum_posts.asp?T ID=1657&PN=1 Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
hello again, was hoping u could post a few pics of your dual fp setup, and maybe a brief description of how u attached the blades to the back of the magnet hub |
