Local Time 17:58 24 Oct 2026 Privacy Policy
Forum Index : Windmills : KD 805 about the VIRYA-3.5B3 available
Adriaan Kragten
Posted: 10:09am 12 Jun 2026
Report KD 805 can be copied for free from my website: www.kdwindturbines.nl at the menu KD-reports. The title of this report is: “Calculations executed for the 3-bladed rotor of the VIRYA-3.5B3 windmill (lambda design = 6, wooden blades, Gö 711 airfoil) with the hinged side vane safety system using the generator of Hefei Top Grand model TGET320-1KW-350R for 24 V battery charging”. KD 805 replaces KD 705 about the VIRYA-3B3 using the same generator.
https://www.kdwindturbines.nl
Adriaan Kragten
Posted: 07:28pm 16 Jun 2026
At 16-6-2026 a new chapter 7 has been added to KD 805. The title of this chapter is: "Drawings of the VIRYA-3.5B3". The drawings of the 2-bladed VIRYA-3.5 have been modified such that now there is a detailed drawing of all components of the VIRYA-3.5B3.
Adriaan Kragten
Posted: 11:25am 17 Jun 2026
At 17-6-2026 a separate folder was made about the VIRYA-3.5B3. This folder can be found on my website at the menu VIRYA-folders. At 18-6-2026 photos have been made of the drawings of the VIRYA-3.5B3. These photos are added to chapter 7. The parts lists are also added to chapter 7.
Edited 2026-06-18 18:32 by Adriaan Kragten
Revlac
Posted: 12:12am 19 Jun 2026
Hi Adriaan, Can you put a link to your web page in your signature profile?
It might be easier to navigate to the website that way.
Cheers Aaron
Off The Grid
Adriaan Kragten
Posted: 10:09am 21 Jun 2026
At 21-6-2026 a manual was made for the VIRYA-3.5B3. This manual is given at my website: www.kdwindturbines.nl at the bottom of the menu KD-reports.
Adriaan Kragten
Posted: 10:19am 21 Jun 2026
  Revlac said  Hi Adriaan, Can you put a link to your web page in your signature profile?
I went to my settings but there is no place where I can mention my website. There is only a place where I can mention my e-mail address and that's given. Therefore my website is mentioned in my first and last post.
Posted: 11:58am 21 Jun 2026
Perhaps manually adding the [TAGS] will work.
Eg.
[url=https://www.kdwindturbines.nl]Adriaan Kragten[/url]
Replace the lowercase "url" with uppercase "URL" at the start and finish so the site will recognize the [TAG=...] and [/TAG]
It should then appear like this in your signature:- Adriaan Kragten
Edited 2026-06-21 22:06 by phil99
Adriaan Kragten
Posted: 04:59pm 21 Jun 2026
  phil99 said  Perhaps manually adding the [TAGS] will work.
Eg.
Up to an hour ago I had nothing mentioned at signature because I thought that signature is something hand written. But now I have mentioned my website at signature and I hope that it works.
