Local Time 18:25 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Bryans 4Kw Motor Conversion
Bryan1
Posted: 08:31am 06 Dec 2025
Well guy's this was one forum where I didn't document this build and every other forum where I did is now gone so no pictures from the build.
I have been talking with the Electrical Engineer at work about my inverter build and the high currents involved etc so I thought to ask the question about slip rings and the high currents that will be there with this motor conversion.
I machined up a new rotor and put 22 N50 16x13mm round magnets on each pole for 88 neo's in total and only broke one magnet along with a sore finger for a week after a brain fart. Then potted with epoxy and machined for a 2mm clearance from the lamination's on diameter.
I did a one wire test and found off memory 30 turns where I went 3 inhand 1.2mm wire was used along with sore fingers after.
Doing a lathe test was fun at 240 rpm cutin saw a flash of 90amps then my VFD complained of over current. So with a 2hp 3 pahse motor and a programmed VFD this conversion acted like a break.
I had a 100amp 3 phase bridge rectifier going into 2 truck batteries in series for 24 volts and on the third test where the same 90 amps was shown on the clamp meter the bridge rectifier let out the magic smoke.
So for years the conversion has sat there and the talk about 460 amp brushs for the slip ring has me thinking time to design and make the slip rings up and finally get this project going again.
Now for the blades I'm going to carve up some red gum to use as I do have a few big dead gumtrees for the donor wood.
There is a story to tell and a long road before this motor conversion is in the air procuding power.
Regards Bryan
Godoh
Posted: 08:30pm 06 Dec 2025
Hi Bryan, so from the beginning of the story, you are using the motor as a generator for a wind generator?
The current (460 amps) should be possible with slip rings, but i am wondering why you didn't wind the stator for a higher voltage and use a transformer at the battery end to drop the voltage back down?
If I were looking for a large set of slip rings, then i would go to a scrap metal yard and look for an old three phase slip ring motor.
That way you would get the slip rings as well as the brush gear you need.
I am also wondering how you calculated that you need 460 amps for the slip rings.
That is a very high current to be trying to draw from a small motor like a 4kw three phase motor. I would think the motor would get too hot if you tried to pull that much current from it.
Good luck with the project
Pete
Bryan1
Posted: 10:02pm 06 Dec 2025
Hi Pete my first motor conversion was that new 1/2hp motor which used the offset method for the magnets and I did put that project on this forum. It did run for many years with those 3 metre oregon blades I made that did fail in spectacular fashion with a bit of them still stuck in my shed roof.
Now for decades I was a member of the fieldlines forum where a member called Zubbly came up with this idea that just worked. Oztules did say the motor conversions are bullet proof and won't burn out as the max current will be limited to what the wire can produce then the eddy currents kick so the current will decrease.
The 460 amp figure was just a figure the engineer came up with as he had used them before as I did ask the question about high current brush's.
Now the best site is ontop of the hill which is around 100 metres from my shearing shed so a long cable run will have to be done. Now whats the bet the site I choose is solid rock about 1/2 a metre down so I will have to buy a rock breaker to go on my mini excavator to get to the depth of the hole for the base.
I do intend to make this a downwind turbine and I will be putting a disk brake on so the max speed can be controlled and that 10,000 amp 240 volt switch I have here will be used to short out the turbine. Why use that heavyduty switch well I do have it here and it may aswell get used.
Basically the rule for motor conversions as one is limited to the nameplate so around 4Kw will be the max the turbine can produce. Going over kill on making everything is the way to go so the turbine can last many years.
Regards Bryan
Godoh
Posted: 11:01pm 06 Dec 2025
Hi Bryan I saw some of zubbly's stuff years ago.
I dont know what voltage you are planning to generate with the turbine, but I cannot see any way that you will get 460 amps from a 4kw motor.
Especially as you say you would the stator with 3/ 1.2mm wires
If you were to run the generator for 24 volts output then I would expect the maximum line current you would get would be 100 amps.
Even then that would be way too much for the windings you have. 1.2mm wire would be good for about 10 amps, so 3x1.2 would really only be good for around 30 amps. Even at that current the motor would get very hot.
Bryan1
Posted: 12:52am 07 Dec 2025
Well I found 3 off 76.1mm diameter brass disks so I'm now on setting up my toolroom lathe so I can face the disks true and 75mm diameter will be the size of the slip ring.We have a heap of poly carbonate round lengths at work so I'll get the separators parted off for me by the guys in the toolroom.
Pete that 460 amps is just a figure and like I said by building with plenty on overkill will ensure it runs trouble free.
The engineer did say he needed a diameter to work with so 75mm it is and I'll find more out tomorrow at work.
MaryB_MN
Posted: 01:01pm 08 Dec 2025
Will be sweet to see this flying! Why go slip ring? Many just use a heavy rubber coated cable and use a quick disconnect at the base of the tower and untwist it 2-3 times a year. Much more reliable! Especially if your prevailing winds are mainly 2 directions.
Adriaan Kragten
Posted: 04:54pm 08 Jan 2026
I have designed, built and tested several PM-generators form asynchronous motors. My experiences are described in my publik report KD 341 which can be copied for free from my website: www.kdwindturbines.nl at the menu KD-reports. If you use the original motor winding, you get a rather high voltage and a low current (see for instance measurements as given in reports KD 78, KD 82 and KD 200).
Edited 2026-01-09 03:18 by Adriaan Kragten
https://www.kdwindturbines.nl
Bryan1
Posted: 07:45am 12 Mar 2026
Well in order to make these slip rings I did need to set back up my rotary table with the 4" 3 jaw chuck, now back in the day I would dial this up in minutes   but move forward a couple of decades since I last worked as a machinist dialing this in was hours of fun only to find was getting no where.
So took of the chuck plate off and as I did bore a 30mm diameter hole in the plate and the rotary table has a 24mm bore, machined up a locating boss then getting opposing points within 0.04 was good enough for me
Now trying to draw this up will be a nightmare on my A1 drawing board so I'll just use a scrap book to roughly hand draw it up.
The poly carbonate disks do need to faced in my toolroom lathe and with the brass disks being 1/2" a 10mm carbon brush will be the go.
Basically I want to get this made then I can take in to a sparkie store and order the right brush's so I can fabricate the mounting up.
Regards Bryan
