Local Time 00:19 25 Oct 2026 Privacy Policy
Forum Index : Windmills : A 12-Volt Lifestyle
MacGyver
Posted: 03:22am 11 Jun 2009
I'm in the process of changing EVERYTHING I use to 12-volts. The reason
is, I have the desire to show folks how easy it is to live off the "grid".
I have already changed my engine lathe to 12-volts. With a 2-speed, 12-
volt motor, a high and low range gearbox and a three-stepped pulley
mandrel, I instantly have a 12-speed lathe. To be honest, I usually leave
it in a mid-range speed unless I'm trimming to .0005 (not often) at which
time I slip it into afterburner mode.
I'm working on an idiot-proof 12-volt charging system that is air driven
and can be built with a screwdriver and drill press. A few of the parts
really need to be cut on a lathe, but for those, I'll be offering online "Care
Packages" for next to nothing.
Next up is a 12-volt clothes dryer and a permanently-mounted 'shop vac'
that will suck your socks off!
When it's all said and done, I will present (with working models featured
online) an almost idiot-proof method to enjoy an all-electric house off
grid.
Hide and watch. As things progress, I'll throw up a Web page and hand
out links.
Oh, the reason I've decided to make it 12-volts is because the automobile
industry has flooded the marketplace with all kinds of nifty 12-volt
hardware available just about world wide at next to no cost.
When you consider the difference in price between a deep-cycle battery
and a garden tractor battery at Wal Mart for around $15, it kinda makes a
fella sit up and think! When the cheap one fails, buy another one and
recycle the dead one. Hey, it's the American way!
Copeville, Texas
marcwolf
Posted: 06:45am 11 Jun 2009
I was reading an interesting article a while back re 12V in the auto industry. The article was saying that auto makers are seriously thinking of moving to a higher (48v) voltage to reduce wiring costs.
Although using auto cat-offs is a neat idea re recycling. One project I did I used a group of air valves that came out of a clinate control system.
Take Care
Dave
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
Tinker
Posted: 02:42pm 11 Jun 2009
Macgyver's 12 Volt clothes dryer is something I'm looking forward to see. The 1000 or so Watts required for a reasonable performance will make the wiring an interesting challenge
Ditto with the 'shop Vac', which will also be in the 1000W+ league if its 'to pull the socks off'.
Just look at the wiring to the starter motor, which, in a small car, is around 1000W. And its rated to run only a few seconds! Well, that's maybe long enough to 'pull the socks off'
In my opinion, 12V and anything to do with heating (other than a small fish tank) is not an economical proposition.
Klaus
MacGyver
Posted: 04:39pm 11 Jun 2009
Tinker:
You're thinking inside the box. All the real fun is outside where I hang out!
Edited by MacGyver 2010-01-21
Copeville, Texas
takagari
Posted: 01:53pm 30 Jul 2009
Looking for more on this. Would lvoe to wire my shop for 12 or 24 vdc LED lighting. And light the whole shop off a simply windmill :D
Have you thought of 24vdc. Less wire, and most diesel sits are 24vdc allowing you to still find lots of stuff, and a simple 24 to 12v step down is easy to make/buy
MacGyver
Posted: 05:51pm 30 Jul 2009
I chose the 12-volt application to be able to take advantage of all the
automobile goodies currently manufactured and on shelves everywhere. I
intend putting up a Web site that gives instruction as well as pictures so
others can do as I have done and reap some free power.
My goal is to design windmills, air engines and generators that can be
built with off-the-shelf parts and a minimum of tooling. I personally
have a full machine shop, but that's me. I realize lots of other folk have
the desire, but not the means to buy a lathe or mill or whatever. To that
end, I'm designing stuff that can be put together with hand tools.
A good example of what's going on is the air pump I've been building for
the past YEAR! It's just a little diaphragm pump that is powered by my
windmills. It's not that it's such a hard project; it's that I keep improving
the design, making it more and more simple.
When the time comes, I'll put it all on the Internet and let everyone in on
the fun.
Some of the air engines do require some complicated machining. To that
end, I intend offering those parts online for a very small fee for anyone
interested.
By the way, all my electricity is made down on the ground using air-
driven engines mechanically connected to a generator. I store the 12-
volt electricity in small garden-tractor batteries.
The only machinery atop the windmill tower is the turbine and an air
pump. My windmills only pump air. Each time the turbine turns, a small
spurt of air is pumped down the tower (pipe).
I don't give much attention to over-speeding and therefore don't have
any complicated furling or feathering equipment to worry about. If I think
things are getting out of hand, I simply crank off the valve on the tower
and the pump has to pump against a dead head of air pressure. That
slows it to a stop in no time at all.
I use solid-aluminum blades (well balanced!) and no governor. The
blades are flat and simply bite the wind. They cannot spin fast enough to
part (break) in any wind (the metal I use has been static tested to forces
not attainable by centrifugal motion).
Simplicity is the goal. That's something everyone can get themselves
around, eh? My favorite tool is my imagination,.
Copeville, Texas
takagari
Posted: 07:18pm 30 Jul 2009
Thats awesome.
I will be building a 1500sqft home, along with a 2000sqft facility for reptile breeding. which promtps me to keep the temp in the building at a solid 80.
So The more I can save money the better, Being in Canada it can hit some pretty cold temps.
I've been trying to pic the net on DIY ways to build wind generators that power more than a light bulb.
KiwiJohn
Posted: 09:41pm 30 Jul 2009
12 volt clothes dryer? That will be interesting to see meanwhile we will continue with the solar powered version.
brett
Posted: 12:14am 31 Jul 2009
MacGyer
I love your ideas and am planning to try something simular with my new workshop.
Plan is to use a windmill like you to pump air, have that air store in a very large aircompressor cylinder. Convert all my shop tools to air driven tools where possible. Hand drills, sanders, rattle guns, the list goes on.
I also plan to use the air to pump water up from my bore using a brumby pump.
All that should cut my energy use. I will still run my heavy tools Lathe, welder, drill presses on 240v but cut the other costs down.
I look forward to any information I can get regarding your air pump, and maybe later the air driven generator and I will run all 12 lighting in the shed.
regards Brett
MacGyver
Posted: 12:39am 31 Jul 2009
Brett:
I've been at this for 40+ years. If you can wait until I post the Web page,
it'll save you a lot of shop time.
Basically I've designed a diaphragm pump that operates off a cam
mounted on the windmill's shaft. It sounds easy, but is fraught with little
problems. My goal is to make this so easy you'd have to pay someone to
help you mess it up.
With compressed air, the trade off is based on volume. I've built oodles
of "steam" engines over the years and as many that run off compressed
air. To get similar "POWER" from the air engines, the pistons (I use
diaphragms a lot) have to be quite large. The stroke is short and the
pressure is low, but with a large surface area, the output power is
regained (basic hydraulics).
I am a plumbing contractor in real life and as such come across many old
water heater tanks that are changed just because they're old and not
necessarily because they leak. These make dandy receivers. I connect
several in parallel and use check valves to assure that a leak in one
doesn't drain the whole system (one check valve per tank on the inlet of
each does the trick).
As you may have guessed, I have way more than just one windmill! Each
mill spins as it will and each has a slightly different displacement. The
ones that have large diaphragms don't spin at all when the system
pressure is up, but when I use a glut of air, they're off and running again
and so on.
Hope all this helps you get a perspective of where you're headed using
compressed air as your primary energy storage.
Copeville, Texas
MacGyver
Posted: 12:51am 31 Jul 2009
KiwiJohn:
Okay, I got a little flak from someone else on this (tinker?) so I'll let the
cat out of the bag.
My 12-volt clothes dryer uses a small stainless-steel basket out of a
commercial "stackable" laundry unit. The basket sits on a central axle
with a tapered roller bearing at the base. The axle acts as a centering
device so the thing doesn't become airborne. The thing spins the clothes
dry.
I've devised an electro-mechanical transmission that lets me spin the
thing up to scary speeds. As the it whirls around, centrifugal force
powers the water through the clothes and out of the drum (which has
little openings). The sprayed water collects on a circular shield wrapped
around the device and water droplets drip off the bottom.
Really simple idea. And just in case you're wondering, NO the clothes
don't shrink from heat; there is no heat. After "drying" in the contraption,
the clothes must air dry for a while to be REALLY dry, which is along the
lines of the clothesline pictured above. My contraption cuts the drying
time down to less than a half hour in most climates.
I'm not the first one to come up with this, by the way. There is a
commercial electric unit out there for campers that uses the same
principle. I googled it and found one about the size of a blender that will
dry a shirt or pair of socks in about a minute. Mine is huge in
comparison.
Now you know.
Copeville, Texas
brett
Posted: 02:47am 31 Jul 2009
Thanks MacGyver
My new workshop is not built yet so I am happy to wait till you post the website.
I will keep an eye out for old HWS tanks, anything else I should keep an eye out for.
Brett
KiwiJohn
Posted: 02:48am 31 Jul 2009
Ah well MacGyver you will probably know that the F&P devices much discussed on this site start their lives doing a very similar job!
Sorry if you thought I was giving you flak with the solar powered clothes dryer but around here a clothes dryer means killowatts of heat and crispy dry fluffy bath towels.Edited by KiwiJohn 2009-08-01
Posted: 03:14am 31 Jul 2009
Ah yes, that explains it. Us southern parts people call that a spin dryer, not a cloths dryer. Same difference really, except one uses heat to tumble dry the cloths. In the tropics during the wet season it will rain for days and nothing gets dry unless you use heat.
I remember a spin dryer my parents, or was it my grand parents, had that was water powered. The garden hose was connected up and the force of the water would spin a big perforated drum up pretty fast. It did a pretty good job.
KiwiJohn
Posted: 08:56pm 31 Jul 2009
MacGyver, if you are interested in a 12V spin dryer you might also be interested in the principles of a 'manual washing machine' I saw demonstrated once.
It was a simple container into which clothes, water and washing powder was put. Then a handle was turned which tumbled the container giving the clothes a real good shake up. The secret of the claimed effectiveness was that the container was sealed (in fact it had been made from a domestic pressure cooker) and the agitation caused a considerable increase in pressure which greatly enhanced the action of the washing powder etc.
Food for thought? Maybe.
Posted: 11:44am 04 Aug 2009
How about a wind power washing machine....
Photo from the book "Home Made Houses" by David Liddle and Ann Taylor.
Tinker
Posted: 02:25pm 04 Aug 2009
  Gizmo said   How about a wind power washing machine....
It took a while to figure that one out
"blow hole effect"
Klaus
grub
Posted: 09:39pm 04 Aug 2009
Yes, I see it now. I originally thought that the mill was lying down for maintenance or some such thing.
Aren't some people just too clever.
MacGyver
Posted: 12:38am 05 Aug 2009
I'm told it takes fewer muscles to smile than to frown. Being basically old,
fat and lazy, I smile a lot and actually enjoy stuff like this.
Of course, if you know anything at all about those 'inventive' types, you
surely realize that "That won't work!" and "You can't do that!" and so on
merely spurn us on!
For example, having had chronic asthma all my life, I created a new
'treatment' that works better than any I've tried to date (and I've tried
them all!). Have a chair and I'll share my secret:
I replaced .01% by volume albuterol sulphate with 35% by volume spiced
rum (70-proof) in my 'nebulizer' and it not only works better and faster,
but costs next to nothing. Last evening I manufactured a portable unit for
my car so I can take "air" treatments away from home. Look out world,
I'm now mobile! No, it doesn't give you a buzz.
I realize some of my posts seem far-fetched and almost silly to some. As
soon as I have enough new clean data (pictures and tutorials) to put up a
Web site, I'll do it and everyone can rethink their position.
It's true, I'm probably the only guy on the planet whose windmills pump
and store air, but it works for me. My goal in all this is to create usable
alternative-energy systems that can be built and maintained by almost
anyone with an interest.
For anyone thinking I'm in this for the money, relax. I figured the money
thing out long ago. I'm into this for fun and for sharing, that's all!
Copeville, Texas
Posted: 01:00am 05 Aug 2009
Hi MacGyver.
Well I for one, who also spends too much time in the workshop inventing, do believe you and all your crazy inventions. I enjoy your posts and they are a valuable part of the forum.
Keep them coming.
