Local Time 07:56 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Wire size/type
Pierre61
Posted: 08:44am 09 Jun 2009
Qualifier: I'm a mug with electronics with too little knowledge but a lot of enthusiasm.
I'm having trouble with my 600w 24 v chinese wind gen. The supplied regulator had a faulty circuit board, which after some soldering repairs now allows about 3 amps of power in in good winds. Pretty poor. It seems to load up/break( is that the correct terminology?) the wind gen too much. Even when batteries at low of 23.1 v.
I used standard household lighting wire to connect the generator to the regulator over a 20 metre run. What should I have used?
Could someone suggest a good 3 phase 24v regulator?
windlight
Posted: 12:10pm 09 Jun 2009
I don't know if your 20m is Dc or AC 3 phase but if you used 2.5mm sq that should transfer 600 Watt, not ideal if it's single phase but should not be your problem.
Attached,http://www.kilowatts.com.au/calculator-voltage-drop .php.
I know nothing about the Chinese mill you have but 3 amps is indicative of the control board still being faulty.
I would convert the 3 phase to Dc then control battery voltage by a normal dump load controller, many options there. Maybe the mill needs some interaction with the control board, others will know that.
allan
GWatPE
Posted: 01:40pm 09 Jun 2009
Hi Pierre61,
How far is the controller from the battery?
Gordon.
become more energy aware
Pierre61
Posted: 07:51am 12 Jun 2009
The controller is less than a metre from the batteries. The wind gen is 20 metres away plus the 6 metres of wire supplied with unit.
So, from the unit , its 3 phase ac for about 26 m via supplied wire,spliced/joined into household lighting cable until terminating into three inputs at back of controller/regulator, then 3mm cable/ single phase to batteries.
Pete
