Local Time 08:34 25 Oct 2026 Privacy Policy
Forum Index : Windmills : N35 vs. N52
DaViD
Posted: 03:45am 27 Mar 2009
Hi guys, Has anyone used the N35 and the N52 in the same application to see what the performance differance was? And if so did you make any tables showing the differance?
If your not living on the edge your taking up to much space!
niall1
Posted: 05:00am 27 Mar 2009
hi David
if you mean switching to the higher grade in a machine where the prop was fairly well matched to the alt already (existing mags)
then then the effects migh,nt be so good
now the alt will generate at a lower rpm which would propabely stall out the prop giving less power overall..
niall
DaViD
Posted: 05:11am 27 Mar 2009
Thanks, that makes sense assuming the cogging would be a (lot) higher?
niall1
Posted: 05:59am 27 Mar 2009
sorry i was thinking along axial flux lines , but your right on an iron core motor that cogged maybe just a small amount you could create a cogging beast that might hold down the prop completly in low winds
just sometimes less is more     Edited by niall1 2009-03-28
niall
DaViD
Posted: 09:17am 27 Mar 2009
Oh yes! less money! my wife screams
imsmooth
Posted: 11:23am 27 Mar 2009
If you are using the F&P rotor you should not go above N35 as the magnetic
forces could begin to warp the rotor when they interact with the iron cores
in the stator. I found N35 way sufficient, and the iron current losses will
start limiting any gain.
oztules
Posted: 12:58pm 27 Mar 2009
In an axial flux.... more is better, as you can use less turns for the same cut in, and introduce resistance into your load lines rather than the stator to shift the heat away from the genny. (must have resistance somewhere to be able to generate usefully with wind)
For induction conversion... more is better, even completely saturating the stator core is better than not... If your rewinding, it is all good, if you are stuck with weak original windings, matching your battery bank may be problematic but more flexibility with using different wiring schemes with the available coils is more likely with stronger than weaker magnets.
Matching the load to your turbine is still the paramount concern, but this whole business relies on wire moving through magnetic fields... bigger the fields, the less wire.. the less resistance, and everything good follows from this.
Bigger magnets allows you to design for less back MMF, less armature reactance, less inductive reactance, less resistance, less heat... etc........in short, less synchronous impedance.
But you still need to match your prop to your load to be of benefit (as Niall points out.)
In an F@P, Imsmooth and Bruce have the runs on the board, and it appears mechanical issues are relevant, and iron loss goes up with stronger magnets.
The iron loss can be compensated for with bigger blades as the cut in will drop anyway, so may not be a real problem if you can change blades.... but the rotor case falling to bits is more of a problem.
........oztules
niall1
Posted: 01:29pm 27 Mar 2009
pretty neat....never thought about the options on re wiring the stator
if its an axial you might even be able to run it with a bigger air gap (less chance of coming in contact with the stator especially on large rotors ).....mmmmm Edited by niall1 2009-03-28
niall
GWatPE
Posted: 01:54pm 27 Mar 2009
The rotor distortion problem seems to happen with the externally caged AxFx mills, with thin rotor disks. I believe someone has an AxFx unit with 1" thick 2" rounds with 1/4" rotor plates. The higher magnet strength probably comes at a significant cost, for the 40% stronger field. I have only seen 3mm thickness mags at >N50 strength, and these only had 80C rating. I would opt for the higher temp rating. I use 120C rated mags.
For a test unit, to see what could be possible, without budget constraints, then the strongest mags would be the go. Reality will come and bite eventually.
Gordon.
become more energy aware
DaViD
Posted: 06:09am 28 Mar 2009
Thanks guys I'm going to try the 2" X 1" X 1/2" N54 rectangle mags. on a dual stator config. to see if I can make a dual work for me. I'll go ahead and order the N35 also. If I dont need them on this project I can always use them on another.
rothko
Posted: 08:16am 28 Mar 2009
Which grade's the most cost effective, in a magnetic flux/$ sense?
DaViD
Posted: 09:25am 28 Mar 2009
Hi rothko, only from a flux vs. $$ the N35 mags would be better in my opnion.
GWatPE
Posted: 11:40am 28 Mar 2009
Hi DaViD,
I found the higher magnet strength was not cost effective as well.
I am not real keen on the rectangular magnets on an AxFx config. My prototyping with magnet ring diameters below 12" showed that rounds are better use of the space. You can get more usable magnet volume into the same space. Above 36" rotor diameters, there may be merit in rectangular blocks as the segmentation gap voids are not as pronounced. This size would be a difficult undertaking to make.
Gordon.
Edited by GWatPE 2009-03-29
DaViD
Posted: 12:47pm 28 Mar 2009
Hi Gordon, When you say rounds are you meaning disks or the washer type with a hole in it?
GWatPE
Posted: 12:39am 29 Mar 2009
Disks are the norm. No point in having a hole in the middle. Air can't produce an emf.
Gordon.
DaViD
Posted: 04:12am 29 Mar 2009
Gordon what size disks are you using?
GWatPE
Posted: 11:42am 29 Mar 2009
Hi DaViD,
All my info is on the F&P@PE thread.
Gordon.
DaViD
Posted: 11:10am 30 Mar 2009
Hi Gordon, i'll get some of the 2"x1/2" disks and try them out they seem
to be cheaper than most others too
