Local Time 08:22 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Axial flux windmill
Arthur
Posted: 07:19am 15 Mar 2009
Hi I am building a twin rotor of the above type. I have seen an an american website I beleive a very nice stator molded from some sort of white plastic. I'm going to make myself look silly here (not for the first time) bur has anyone molded a stator with plastic? I would like to recycle a plastic table"""" AND SOME PLASTIC PIPING. I
have not done any plastic molding but at a place I workedd they fed plastic granules into a heater, this was injection moulding. I'm wondering it the container would have to be sealed to melt the plastic? Any comment gladly received; even nasty once    Arthur
GWatPE
Posted: 01:07pm 15 Mar 2009
The material for bonding the stator should be a cross-linked polymer, and not a thermoplastic polymer.
Gordon.
become more energy aware
Tinker
Posted: 02:07pm 15 Mar 2009
  Arthur said   Hi I am building a twin rotor of the above type. I have seen an an american website I beleive a very nice stator molded from some sort of white plastic. I'm going to make myself look silly here (not for the first time) bur has anyone molded a stator with plastic? I would like to recycle a plastic table"""" AND SOME PLASTIC PIPING. I
Arthur, plastics ain't plastics, they're not all the same. There are LOTS of types and they have all different properties. You're much better off using epoxy or polyester type resins but DO read up on them before using if you are not familiar with their properties.
I have seen an injection machine in action, its not something you could reproduce in your garage even if you did get hold of the correct plastic granules.Edited by Tinker 2009-03-17
Klaus
Arthur
Posted: 02:17pm 15 Mar 2009
thank you both for your replies, I dont knoe anything about fiberglass resins less than about plastics I guess :)
No was not thinking of making an injection machine hi dont haave the facilities even if it would have been of any use.guess i will have to keep on looking at those plastic pipes. cant find the website where i saw the plastic stator either. Arthur
