Local Time 08:31 25 Oct 2026 Privacy Policy
Forum Index : Windmills : chinese mill no o/p on on 1 phase
rgormley
Posted: 04:36am 09 Mar 2009
i was fiddling around with the voltage doubler and getting no output, so then i measured the raw AC voltages on the 3 wire comming from the mill, i think there is a problem
between wires 1-2 i get 12-18 vac (light winds)
between wires 2-3 i get 1-3vac (light winds)
between wires 1-3 i get 1-3 vac (light winds)
should i see roughly the same volts across all phases?
for the moment i have hooked wires 1-2 acroos a bridge (no doubler) and i see small charge going into the batts
CraziestOzzy
Posted: 06:50am 09 Mar 2009
assuming it is unadulterated three phase, yes you should have equal resistance (and also AC voltage) out of each of the three leads (excluding a possible existing neutral) coming out of the generator.
Need to know the specs of the generator you have to see if the manufacturer (yourself included if a DIY job) has not made any shortcuts internally to make life easier (such as internal rectifier causing output of DC etc)
It appears number three lead may also have a short Edited by CraziestOzzy 2009-03-10
