Local Time 08:30 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Hamish is on da way Look out Gizmo
Bryan1
Posted: 08:55am 06 Mar 2009
Just looked on the bom and Hamish is on a close path to Mackay, so hopefully Glenn will get all his wind mills tied down and everything safe.
Here's a tip we used to do in the pilara when a cyclone was coming around. Fill ya bath tub with beer and ice, when the power goes out put ya food in sealed bags in the fridge. When the beer runs out ya got plenty of water to drink and cold food thats still fresh....
When cyclone Steve ripped thru we did this and lasted the 7 days without power, water and with winds so strong you couldn't go outside.
Here's hopin that miss's you Glenn and I hope ya all prepared.
Cheers Bryan
Posted: 10:13am 06 Mar 2009
Yes I'm a little anxious. Will know tomorrow if its a threat, and then I'll start taking stuff down and boarding up windows. I can take down the F&P windmill easily, but the Southern Cross is not so easy, so I'll climb up and tie it up to stop the turbine spinning. And I'll take the solar panels off the roof, I might be needing them if the power goes down for a few days so I'll put them somewhere safe. The only tree near the house is a big palm, but they tend to loose their leaves and stay upright in storms.
Fingers crossed.
Posted: 10:22am 06 Mar 2009
Actually, does anyone know of the best way to secure roller doors to stop them blowing in or out. I was going to dynabolt the bottom rail to the floor, but this wont stop the middle bowing in or out.
CraziestOzzy
Posted: 07:40pm 06 Mar 2009
...now I have opportunity to see if my wind generator will outperform my expectations...
DaViD
Posted: 09:34pm 06 Mar 2009
Hi Gizmo,
I'm not sure I know what you mean by a roller door.
I have two buildings one with an overhead roll down door and one with two doors that come together in the midddle on a track at the top. since we get a few tornadoes here I attached a 2" x 8" x 12ft. board to the inside of the doors then attached another of the same to the one on the door then anchored it down with a short rebar through a hole I drilled in the wood. The rebar was bent in the shape of a hook to keep the board from sliding off. Also I drilled a hole in the concrete so I could drive the rebar down and remove it easily. Don't know if this helps on your door though.
If your not living on the edge your taking up to much space!
sPuDd
Posted: 12:26pm 07 Mar 2009
Glenn,
in Atherton when Larry came through, I ran self drilling tech
screws through the rail-door-rail to pin them into place.
Only need about 4-5 in each side. The door I secured
survived, the other that I piled gear up against blew
in and hurled 200kg of stuff through the carport.
They screws are easily removed and can be used again.
sPuDd..
It should work ...in theory
Posted: 10:29pm 07 Mar 2009
Yeah David I think it would be called a overhead roll down door. The door itself is a length of corrugated steel that is fed off a roll at the top of the doorway.
Hey Spudd I did think about drilling through the rail into the door skin but I wasnt sure if this would affect the way the door slid in the rail once I took the screws out. I have added more screws to the rail and door frame to make the rail more rigid, and I've replaced the door locking bars with a full length steel bar that ties into the frame at both sides. Fingers crossed.
This is the latest tracking map. Its a nasty one
divemaster1963
Posted: 03:46am 08 Mar 2009
hay gizmo
tha only way to protect a roll up door is to brace the center with a x brace corner to corner and one across the center half way up then lever brace to the center. we lost 4 rollups during tonados last mothers day here in ga.usa. the only one that stood was one that was being worked on and had the bracing. It with stood winds apx 250mph for over 20 mins.
good look stay safe.
divemaster1963
DaViD
Posted: 01:56pm 08 Mar 2009
Hey Glenn, Is there any way you can fit a board verticaly behind the bar
that you installed so it would support the panels from moving inward?
DaViD
Posted: 10:06pm 08 Mar 2009
Hi Glenn, This is why my doors have to be braced
itjust missed us
SparWeb
Posted: 06:37pm 09 Mar 2009
David,
Something looked wrong with that side-ways picture...
Until I realized that TV broadcast from Australia looks like this when it gets up to North America...
CNN also looks like this when viewed in Australia...
Steven T. Fahey
CraziestOzzy
Posted: 07:40pm 09 Mar 2009
Here in this great land of ours, we see the world differently...
image from flourish.org Edited by CraziestOzzy 2009-03-11
DaViD
Posted: 09:20pm 09 Mar 2009
I don't know why but my Iphone uploads pics. Sideways sometimes
DaViD
Posted: 03:06pm 10 Mar 2009
Well fellas I guess I've opend a subject that has a lot of professors grinding their teeth and scratching their heads. There is a prof. from M.I.T supposed to call today. This guy should know he is a teacher and lecturer on rotordynamics design and development.
DaViD
Posted: 03:07pm 10 Mar 2009
Godd god this is wrong topic I must be asleep
