Local Time 07:43 25 Oct 2026 Privacy Policy
Forum Index : Windmills : resistance
DaViD
Posted: 05:11pm 09 Feb 2009
Hey guys,
I have a stepper motor out of a lexmark printer with four wires the resistance on two wires is 6.4 on the other two it is 6.3 is this right and if so how do I wire it? THANKS
                        Dave
If your not living on the edge your taking up to much space!
niall1
Posted: 10:50pm 10 Feb 2009
hi david
sounds like you have two individual phases (the resistance is usually a few ohms) ..if so putting a bridge rectifier on each reading pair and paralleling (or maybe using a cap to series )the outputs should give you a buzz ...there might be a gearing unit on it which might be fun ...often the bigger the printers the nicer the motors
niall
DaViD
Posted: 01:00pm 11 Feb 2009
Thanks, I'll try it and see what happens
