Local Time 07:43 25 Oct 2026 Privacy Policy
Forum Index : Windmills : motor
DaViD
Posted: 03:07pm 05 Feb 2009
I have one of my airless industrial paint sprayer motors that is 120ac,11amp,1.75Hp,160volt dc,3200rpm with a built on reducer (not sure of the ratio since the output shaft is off center for a piston) 1200watt,cont. duty,27.4lb./in. perm. magnet type.
I will guess from experience with this pump that reduced rpm is around 600-700 so is this motor sutiable
for a generator?
Thanks guys.
If your not living on the edge your taking up to much space!
