Forum Index : Windmills : MMBasic windows simulator
| Chrisk Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 137 |
Hi all When using TRON within MMBasic the simulator on my windows machine, why don't the execution line numbers coincide with the lines of the program displayed by MM Edit. Is it a version problem with MMBasic? Chrisk |
I think you meant to post this in Microcontrollers sub forum. Post a short example of what doesn't work for you (in the microcontrollers area). A simple test here looks OK Jim VK7JH MMedit |
