Local Time 07:30 25 Oct 2026 Privacy Policy
Forum Index : Windmills : ebay
DaViD
Posted: 03:31pm 22 Jan 2009
I have been looking around on Ebay and have seen a lot of servo motors. Is there any one motor that is really suited for wind power or is it just a matter of what i want to build?
If your not living on the edge your taking up to much space!
Posted: 12:31pm 23 Jan 2009
Hi David
Its depends on the operating voltage and how many $ they want for it.
The higher the voltage the better, a servo that runs at 100 volts or more would be fine. The bigger ( higher watt or amp rating ) the better to, again depending on price.
Servos come as either DC or AC. Either will work, but AC is better if you can get it. DC means brushes, and these will wear out. AC types are usually 3 phase, good.
luckeydog
Posted: 06:52am 26 Jan 2009
Hey David
I am new here but not new to wind power. so this will be my first post on this Website.
Glen is correct higher voltage is better, But also important is the rated RPM
so high voltage low rpm and high amp rating is good.
For example
A 110 volt motor rated at 3500 rpm
is better than
a 110 volt motor rated at say 4600 rpm
3500/110 =31.81 this means 31 rpm per volt so achieve say 12.5 volts you would need to spin your motor at 397 rpm
so this example motor would not be a good motor to use as a direct drive.
A good motor for a small turbine say 120 watts
would be something like this
50 vdc at 900 rpm
12 amp
900/50=18 one volt per. 18rpm
18* 12.5=225 rpm a reasonable rpm for a 6 foot turbine
I hope this makes scene.
I hope i did all my math correct.
Luckeydog
wind gens are so much funner to watch than solar panels
http://www.coloradowindpower.com
