Local Time 07:30 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Mikes windmills
sawtron1
Posted: 11:41am 17 Jan 2009
Hello, All,
Has anyone had anything to do with a Mallard 800E wind turbine from Mikes windmill shop, looks a great unit,anyother comments please.
Sawtron1
wdyasq
Posted: 11:32pm 17 Jan 2009
Things to look for in these new wind-turbine shops on the internet.
Does it use a modified automotive alternator, if so deduct 2 points.
Does it use metal blades, if so deduct 2 points.
Calculate swept area, calculate possible output if output exceeds Betz limits, deduct 2 points. If output exceeds theoretical, deduct 4 points.
If the mill has more than 3 blades, deduct a point per extra blade.
Start with 10 points .... if you end up with less than 9 points, look somewhere else.
Ron
I'd say I hate to be so negative but I believe there is a small industry that will destroy small wind turbine acceptance. Products like the one mentioned will hasten goobernment intervention and regulation.
Adventure is just bad planning." -- Roald Amundsen
