Local Time 07:30 25 Oct 2026 Privacy Policy
Forum Index : Windmills : ametek motor
greif
Posted: 04:37am 14 Jan 2009
hi
I would like to do my first small windmill using a motor (ametek type) but cannot find ny good ametek's.
I want to start this way just to get experience and work my way up to better things
http://greenterrafirma.com/permanent-magnet-motors.html
this site list good and bad models of ametek
does anyone know of a good motor to use and where to buy it
thanks
wind-pirate
Posted: 01:50am 15 Jan 2009
look for a treadmill motor. They are quite easy to find.
Try to get one with lower RPM's. Some seem to run upwards of 5000 RPM's. I found one that is
15 amps
90 volts DC 3.5 H.P.
3,600 RPM's
I reaches 20 volts @ 1100 RPM's. so I belt drive it with
1 to 2.5 ratio, 4 blades 5 foot. It work not bad.
An axial flux would work better. But I had to try it.
THE Pirate.
stealing wind & solar energy is fun
niall1
Posted: 02:43am 15 Jan 2009
hi greif
theres some info on this site about ameteks ...
http://www.windstuffnow.com/main/products1.htm
and some home build ametek info here too
http://www.mdpub.com/Wind_Turbine/index.html
paste the links into your address bar ...hope they work ....have to figure out how to paste links !
i really liked the way the ametek i had didnt cog (very smooth to spin up) ...i sold it on later ....kind of sorry i didnt keep it
Edited by niall1 2009-01-16
niall
greif
Posted: 01:15am 16 Jan 2009
thanks guys
I have been on those sites and they are good but am having trouble fimd a motor to use. They say the ametek 99 and 30 are the best but cannot find those.
I will try to find a treadmill motor with low rpm's
thanks
greif
Posted: 01:29am 16 Jan 2009
http://cgi.ebay.com/2-0-HP-TREADMILL-MOTOR-HEAVY-DUTY-NOS_W0 QQitemZ250355239741QQcmdZViewItemQQptZExercise_Fitness_Cardi o?hash=item250355239741&_trksid=p3286.c0.m14&_trkparms=72%3A 1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C29 3%3A1%7C294%3A50
how does this look?
GWatPE
Posted: 05:03am 16 Jan 2009
This motor, and a similar motor on the same EBay link are 130V@3200rpm. I noted 15A on one rating plate. These could be used in a 6-12V system at appprox 100-150W Max output. Bear in mind that probably more than half the power output will just heat the windings.
The treadmill motors keep being touted as good for windmill applications, but the rating plates suggest otherwise.
Gordon.
become more energy aware
