Local Time 07:30 25 Oct 2026 Privacy Policy
Forum Index : Windmills : A different Windmill
Greenbelt
Posted: 02:34am 12 Jan 2009
A common conveyor belt, Add a couple of mods
in the right places and you have a real green machine. It is adaptable
to wind and Hydro sources. If anchored properly it can take awesome
abuse and the cost is downright thrifty. There are thousands in the
back lot of old factories and warehouses, Gravel pits, clay and brick
yards. Here are a few ways to use this ugly all purpose greenie.
As a water wheel application; A standard water wheel with buckets
accepts the water just
past top center, at this position the weight of water has very little
torque on the drive shaft
then as the wheel moves it to the 90 Deg. position it is most effective
here, as it rotates
the torque again becomes less and less to 180 Deg. bottom center.
Now evaluate the SANTA ANA All buckets (optional # ) are positioned at
90 Deg.with respect to the drive shaft rotation this means that the
weight of water is 100 % effective from top to bottom, This results in
Gobs of torque to drive the Gearbox. Worm or Screw drive gearboxes
should be avioded because the screw has a tendecy to bind when
backdriven by gear teeth..
it can be used as a swift water machine on creeks rivers, tide pools
And with some engineering it could be scaled to a megawatt size .
The Santa ana could drive an automobile air conditioning compressor. A
Heat pump
with its 3 watt for 1 watt efficiency is the perfect option for wind
power. A 10 MPH. wind will output 1.78 Kw.= 5.34 kilowatts heat value.
There is a design problem that can be overcome with perseverance, A
braking system.
This machine becomes a "MONSTER" at 60 MPH. Outputting 516 HP. Belt
speed
is over 87 feet per second, Torque is over 3000 static pounds feet =
385 kilowatts. Don't
even think about it" It would blow up long before this.
Here is the method I used to calculate the output, No losses of
gearbox, Belts or Bearings have been subtracted.
The sails or paddles I will name "Pushplates" are 5x12 feet = 60
sq.ft., There are 5 exposed
to the wind at 0 degree, Only one has 60 sq. ft. and the 4 wind shaded
ones at 30 sq. ft each.
Total =180 sq.ft. Acording to the wind chart, the wind force is 8
-ounces per square foot
at 10 Mph. (180 sq. ft.* 8 oz.=1440/16 = 90 pounds force.) Wind speed
is 14.6 ft. sec.which is also the belt speed. So 90 pounds on a 1 foot
radius moving at 14.6 ft. sec. = 1314 lb. ft. sec.
multiplied by 60 sec. = 78840 / 33000 = 2.39 hp. X 746 watts = 1782.4
/ 1000 = 1.78 kw.
With its huge pushplates the santa ana can not operate at wind speed
above 10 MPH, the end rollers induce a high "G" value to the plates
when they whip around.
In a commercial sized machine the rollers should be 20 or more feet in
diameter, A 28 ft. dia roller will permit 1 full second of time for the
pushplate to reverse direction when the wind speed is 44 ft. sec.(30)
mph.
I'm going to explore this, say I have a design with 28 ft. dia.
rollers, they are 50 ft. long, The
belt frame is a short 200 ft. between roller centers There are 10
pushplates Exposed to the wind , 50 ft. x 20 ft.of lightweight
composite and cross ribbed for strength.
Only (1) plate at full 1000 sq. ft.exposure, 9 more shadowed at 1/2, or
500 sq. ft. Total is(1000 + 4500 X 72 oz. wind force= 396000) divided
by 16 =24750 lb.of force at 30 mph Wind. (14 ft.roller radius X 24750
= 346500 lb. ft. this is static torque. now the wind or belt speed per
sec.(346500 X 43 ft.wind per sec.= 14899500 X 60 sec.= ( 893970000 foot
pounds per minute divide by horsepower constant. 33000 = 27090 HP). X
(.746) = 20209KW. 2.2 megawatts. The output at ten MPH. is 762.4 KW.
This machine should be inverted for all applications, this would make
use of gravity as an aid to fold the pushplates for the return trip and
automatic
deployment. Plate rollers and guide tracks would not be needed except
for deployment to ease
the wind shock. Tried to post a drawing But "oh no" I have posted this item at Instructable's Dot com / community / Green . Maybe some one can use this. Done, DUN, comments?
http://chestofbooks.com/crafts/popular-mechanics/Practical-M echanics-fo
Posted: 01:03pm 12 Jan 2009
Hi Greenbelt.
I think you need to start again with this message. The formatting looks like its been copy and pasted from another source, and the links dont work. Please post another message with some valid web links so we can see what you are working on.
